routing loop help!
soklamarhy
I have a routing loop.
tracert 10.121.62.1 which is the offsit location, loops between two routers here on the main site.
when I try to ping a known IP, I get a TTL expired on transit.
I phoned our provider, everything is set on their end. nothing has changed on either routers. what else could be the cause?
16 Replies 16
vijayasankar
Level 4
Level 4
Routing loops could be due to misconfiguration or due to any link flap or any problem with the routing protocols enroute in the network.
Do you have access to the hops that you see in the tracert.
If so, login to those 2 hops which are looping, and check the output of "show ip route ".
This will give you a clue on what is wrong with the current routing setup on those hops.
-VJ
Yes I do,
I see there is no routing for 10.121.62.1
Subnet not in table.
How do I put this subnet in the table? My other site is D-EIGRP dynamically learned.
Why is this other site not learning it the same way?
do you have any redistribution configured on your router?
If you mean by I assign a static IP for redistributing any IP's under this subnet, then yes I do, back to my core router which loops back to the router that talks to the offsite.
We have a PPP connection w/ serial int.
if you have configured redistribution then make sure you have configure it properly... may be due to missconfiguration of redistribution causes most of the routing loop problem... so will you please post the topology with configuration so we can try to solve it ...
rate this post if it helps
regards
Devang
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
hostname XXX
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 17384 debugging
logging console critical
no aaa new-model
resource policy
clock timezone EST -5
clock summer-time EDT recurring
no network-clock-participate wic 1
ip subnet-zero
no ip source-route
ip tcp synwait-time 10
ip cef
no ip dhcp use vrf connected
no ip bootp server
ip domain name XXX
ip name-server 10.121.26.36
ip name-server 10.121.24.4
ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
voice-card 0
no dspfarm
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/1/1
framing esf
clock source internal
linecode b8zs
interface GigabitEthernet0/0
description *** Old Network ***
ip address 10.121.24.2 255.255.252.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
bridge-group 1
interface GigabitEthernet0/1
description None
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no cdp enable
no mop enabled
interface Serial0/1/0:0
ip address 10.121.101.1 255.255.255.248
bridge-group 1
interface Serial0/1/1:0
ip address 10.121.101.129 255.255.255.248
router eigrp 1
network 10.0.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.121.26.255
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
logging trap debugging
control-plane
bridge 1 protocol ieee
"ip route 0.0.0.0 0.0.0.0 10.121.26.255"
You are pointing the default route to a broadcast address.
It's this part of your current config or a typo while posting the config ?
Lamar said:
"Yes I do,
Why is this other site not learning it the same way?"
Lamar,
The subnet will automatically return to the routing table as soon as EIGRP
is working again between the 2 routers.
If you issue
"sh ip eigrp neighbors detail"
do you see any neighbors listed ? If so, it's that neighbor holding the 10.121.62.0 network ?
No I do not. I called the provider again and they said their end is clean and see no response from the CSU
What does this mean?
The provider should be able to loop the CSU from remote, if they can't try resetting the CSU.
You should work closely with your telco on this problem since it can also be a hardware issue at the telco end or your end.
I have, they have already replaced some double loop circuit board on both ends. Now they are able to have a clean connection so they say, but still unable to hit the CSU.
You suggest I try to reset the CSU? There is an amber light on the serial interface card that is lighted up (AL) or (AC), I forgot the abbreviation for it.
It is an AL light, for Alarm. We have already tried rebooting, and doing shut, no shut on the interface. Still no luck. Can we assume this card is bad now?
Don't assume that just yet. Check cabling from the Dmark to CSU and tell the provider that you have an alarm. They should dispatch someone onsite. If you have a spare CSU try swapping for troubleshooting purposes.
It's an internal or external CSU ?
It is an internal CSU.
We are already ordering a new unit $400 bucks.
I have been working with our provider and they are still unable to hit the CSU unit.
