IOS Options
rahman001
                   Hi everyone,
i want to configure a router with the following configuration options. which IOS should be selected in each option?
1. Cisco1941 with basic IOS
2. Cisco1941 with advance IP IOS
br
sam
8 Replies 8
cadet alain
which configuration options ?
Regards.
Alain
thnaks for quick response.
i want to configure a cisco1941 with basic IOS. i think this should be cisco1941/k9 with the normal IOS universal image.
then i want to configure cisco1941 with an advance IP IOS. how can i go about this one?
br
you don't configure such a thing you have to activate the licence for the image you got.
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html
Regards.
Alain
hi alain,
i have gone through the cisco web link..
how can i activate the license for this image on the ciscp1941.
should i select the data license(SL-19-DATA-K9) plus the security license(SL-19-SEC-K9)?
br
No only  1 licence can be active at a time.
Regards.
Alain
hi alain,
which license can i then activate if i want to achieve an advance IP service IOS?
br
You can order multilple PAKs in one license if needed to combine multiple features into a single license file. Adv IP services traslates into SEC+ UC +DATA package.
See this guide for steps to generate and install the license:
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html#wp9000836
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
As per Ivan above, you can combine in a Pak multiple licenses and very possibly in your case DATA plus Security will be the one required. However, before buying the license check the features with Cisco navigator to be sure you get what you pay for. As per IOS, I do like the 15.2T series. I did implement it with the sec license and I was very happy about it.
Alessio
