IOS upgradation steps in ASR 1006 with redundant RP
madhusudhan s
Hi guys
I need to upgrade image in ASR 1006 from asr1000rp1-advipservicesk9.02.01.01.122-33.XNA1.bin to asr1000rp1-advipservicesk9.02.02.03.122-33.XNB3.bin to support PBR. Since the impect of any failure is huge.. need expert suggestion to complete this upgradation.
=================================Show version================================================
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVIPSERVICESK9-M), Version 12.2(33)XNA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Tue 08-Jul-08 14:40 by mcpre
Cisco IOS-XE software, Copyright (c) 1986-2008 by Cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Intranet_Core uptime is 3 weeks, 3 days, 9 hours, 53 minutes
Uptime for this control processor is 3 weeks, 3 days, 9 hours, 55 minutes
System returned to ROM by reload
System restarted at 03:46:24 ist Sun Feb 7 2010
System image file is "bootflash:/asr1000rp1-advipservicesk9.02.01.01.122-33.XNA1.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1006 (RP1) processor with 752194K/6147K bytes of memory.
16 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
2097152K bytes of physical memory.
937983K bytes of eUSB flash at bootflash:.
39004543K bytes of SATA hard disk at harddisk:.
Amar
Tried but failed.. stuck in step 4...
Step 4:
Load the target consolidated package onto the standby RP.
Router# issu loadversion rp 1 file stby-bootflash:asr1000rp1-advipservicesk9.02.02.03.122-33.XNB3.bin
After you receive the message indicating that the terminal state has been reached, go on to Step 5.
not recieved such message...
Regrads
Amar
