IOS upgrade over WAN (using TFTP)
m.samouka
Hi All,
I need to upgrade my router IOS over a WAN connection.
the problem i face is that when i establish the command: "copy tftp: flash:" it gives my (time out). when i checked the logs on the TFTP server i found that the request is received from the Private IP of the router (the one configured on the Serial interface) not the real IP address.
and the TFTP server machine can't access the router private IP address over the WAN.
Here is the configuration on the router, I'll be so glad if someone can help me is soling this issue.
How can i let the TFTP requests coming from the router with the Real IP which is configured on the Interface Fa0/0?
Current configuration : 1315 bytes
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
archive
log config
hidekeys
interface FastEthernet0/0
ip address 196.219.x.y 255.255.255.224 (My Real IP Address)
duplex auto
speed auto
no keepalive
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/0/0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type q933a
interface Serial0/0/0.16 point-to-point
ip address 172.16.133.2 255.255.255.252
snmp trap link-status
frame-relay interface-dlci 16
interface Serial0/0/1
no ip address
ignore dcd
interface Serial0/0/1.16 point-to-point
ip address 172.16.134.2 255.255.255.252
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Serial0/0/0.16
ip route 0.0.0.0 0.0.0.0 Serial0/0/1.16
no ip http server
access-list 80 permit 196.219.224.1
end
Richard Burts
Mohamed
There is an aspect of your question that puzzles me. The default behavior of IOS is to use as the source address the address of the outbound interface. If the router is using the address of the serial then it believes that the serial is the best way to get to the TFTP server. If the TFTP server is on the inside of your network then why can it not get to the inside address of your router?
But you asked how to get the router to use the address of Fa0/0 and the answer is straightforward. Use this command:
ip tftp source-interface fa0/0
and then the router will use the source address of Fa0/0 for its TFTP traffic.
Rick
Rick
Richard Burts
Mohamed
Rick
Rick
Hi, Thanks alot for the last command ;-)
it solves my problem
For your question; my TFTP server is not on the LAN it's over the WAN so it have to get it through the serial interface but the problem was that it takes the IP of the serial interface which is a private IP between the router and the ISP. and the real IP address is configured on the Fa0/0...
Little bit tricky but it works...
Thank u very much :-)
Mohamed
That helps explain why you need the source address to be different from the address of the outbound interface. I am glad that my suggestion did help you solve your issue. Thank you for using the rating system to indicate that your problem was solved (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that they will read a suggestion that did solve the problem.
Rick
Rick
