IOS XE how to do port forwarding on routed /32 address
Jamesits
the ISP routes a single IP to our gateway router. So our gateway router is set up this way:
int Gi1
  ip address 10.0.0.2 255.255.255.0
int Gi2
int Lo0
  ip address 1.2.3.4 255.255.255.255
ip route 0.0.0.0 0.0.0.0 10.0.0.1
Now I need to forward port 1.2.3.4:80 -> 192.168.1.2:80, how do I achieve this?
Already tried and doesn't work:
1. ip nat source static tcp 1.2.3.4 80 192.168.1.2 80
2. ip nat pool + ip access-list + ip nat source
I tested the config below in GNS3 (change the static NAT entries to tcp port 80):
interface Loopback0
ip nat inside
interface GigabitEthernet1
ip nat outside
interface GigabitEthernet2
ip nat inside
ip nat inside source static 192.168.1.2 interface Loopback0
ip nat outside source static 10.0.0.2 1.2.3.4
and got the debug output below:
R1#debug ip nat
IP NAT debugging is on
R1#
*Aug 4 08:38:45.181: NAT*: s=10.0.0.1, d=1.2.3.4->192.168.1.2 [50]
R1#
*Aug 4 08:38:47.166: NAT*: s=10.0.0.1, d=1.2.3.4->192.168.1.2 [51]
R1#
*Aug 4 08:38:48.167: NAT*: s=192.168.1.2->1.2.3.4, d=10.0.0.1 [50]
*Aug 4 08:38:48.167: NAT*: s=192.168.1.2->1.2.3.4, d=10.0.0.1 [51]
*Aug 4 08:38:48.170: NAT*: s=10.0.0.1, d=1.2.3.4->192.168.1.2 [52]
*Aug 4 08:38:48.170: NAT*: s=192.168.1.2->1.2.3.4, d=10.0.0.1 [52]
*Aug 4 08:38:48.174: NAT*: s=10.0.0.1, d=1.2.3.4->192.168.1.2 [53]
*Aug 4 08:38:48.174: NAT*: s=192.168.1.2->1.2.3.4, d=10.0.0.1 [53]
*Aug 4 08:38:48.179: NAT*: s=10.0.0.1, d=1.2.3.4->192.168.1.2 [54]
*Aug 4 08:38:48.179: NAT*: s=192.168.1.2->1.2.3.4, d=10.0.0.1 [54]
interface Loopback0
ip nat inside
ip nat outside
ip nat inside
R1#debug ip nat
R1#
R1#
R1#
Much thanks! This is working on my setup.
My final config is:
ip nat inside source static tcp 192.168.1.2 80 interface Lo0 80
ip nat outside source static tcp 10.0.0.2 80 1.2.3.4 80
