I'm a little rusty on IOS-XE software updates and looking for some advice
Please see below outputs, I dont recall seeing the system image being the packages file on any ISR's I've logged into before, but it has been a while. Normally I see a specific boot statement pointing at a specifc bin file
I need to downgrade the software to 17.3.5 on this router, my question is with it currently using the packages file, can I proceed in the normal manner of copying the file into flash and adding the boot statement?
thanks in advance
ROUTER-PRI#sh ver
Cisco IOS XE Software, Version 17.05.01a
Cisco IOS Software [Bengaluru], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.5.1a, RELEASE SOFTWARE (fc3)
System image file is "bootflash:packages.conf"
ROUTER-PRI#sh platform
Chassis type: ISR4331/K9
Slot Type State Insert time (ago)
0 ISR4331/K9 ok 4w5d
0/0 ISR4331-3x1GE ok 4w5d
1 ISR4331/K9 ok 4w5d
R0 ISR4331/K9 ok, active 4w5d
F0 ISR4331/K9 ok, active 4w5d
P0 PWR-4330-AC ok 4w5d
P2 ACS-4330-FANASSY ok 4w5d
Slot CPLD Version Firmware Version
0 19040541 17.6.2
1 19040541 17.6.2
R0 19040541 17.6.2
F0 19040541 17.6.2
ROUTER-PRI#show flash: | i mono|rpboot
1779 585220096 Apr 09 2022 03:33:56.0000000000 +00:00 /bootflash/isr4300-mono-universalk9.17.05.01a.SPA.pkg
1780 33417812 Apr 09 2022 03:35:37.0000000000 +00:00 /bootflash/isr4300-rpboot.17.05.01a.SPA.pkg
