IOS XR ip sla command not supported
Shajil Melethil
Hello ,
ASR 9000 (ios-xr) doesnt have ipsla command.
can anyone let us know what is the issue and how to fix,
version is 6.1.4
9 Replies 9
balaji.bandi
it should work as expected
can you go to config t
ip sla ?  (post the output ?)
or
ipsla ?
here is reference guide :
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-5/system-monitoring/configuration/guide/b-system-monitoring-cg-asr9000-65x/b-system-monitoring-cg-asr9000-65x_chapter_0100.html
BB
Here how it is showing
RP/0/RSP0/CPU0:GW1ICPRC02#config t
Fri Mar 26 06:00:58.853 UTC
RP/0/RSP0/CPU0(config)#ip sla ?
% Invalid input detected at '^' marker.
RP/0/RSP0/CPU0:GW1ICPRC02(config)#ipsla ?
RP/0/RSP0/CPU0(config)#ipsla
just to confirm is this a real kit or lab?
can you post-show version
BB
I dont see the option.
i have another ASR9K with same version and i can configure ipsla there.
is there any feature to be enabled or etc ?
odd indeed.
When I look at the command reference, the syntax of the command they give looks slightly different:
RP/0/RSP0/CPU0:router# configure
RP/0/RSP0/CPU0:router(config)# ipsla
RP/0/RSP0/CPU0:router(config-ipsla)#
Hi Shajil,
You need to enable the manageability package, so you can use IP SLA.
Node 0/RSP0/CPU0 [RP]
Boot Partition: xr_lv1178
Active Packages: 14
asr9k-xr-7.1.2 version=7.1.2 [Boot image]
asr9k-mgbl-x64-2.0.0.0-r712 <+++++++++++++++++++++++ This is the package you are missing.
asr9k-mpls-x64-2.0.0.0-r712
asr9k-isis-x64-1.1.0.0-r712
Refer to the following configuration guide to configure ip sla, after installing the manageability package.
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-5/system-monitoring/configuration/guide/b-system-monitoring-cg-asr9000-65x/b-system-monitoring-cg-asr9000-65x_chapter_0100.html#ref_1003836
I have the mgbl file in my disk0; but seems like it is not activated in
router as i dont see it in show version.
How can i specifically activate that package only ?
asr9k-mgbl-px.pie-6.1.4
Please let me know
is there any impact if i do activate it ?
Shajil Melethil
I think below is one i am missing. I have another router having those packages and missing in problem router
below is working one
RP/0/RSP0/CPU0:#s install active detail | in mgbl
Fri Mar 26 16:12:51.299 UTC
      disk0:asr9k-mgbl-px-6.1.4
          disk0:asr9k-mgbl-supp-6.1.4
          disk0:iosxr-mgbl-6.1.4
RP/0/RSP0/CPU0:#
in problemactic router , there is no output. i can copy this file there.
but how to activate the package ?
Try "admin install activate disk0:asr9k-mgbl-px.pie-6.1.4"
