IOS XRv redistribute connected or OSPF
neo2000
Hi Guys,
Scenerio is
(XRv)     (C7200 - virtual)                  (XRv)
R1----------R2------------------R3
I'm testing L3VPN in EVE-NG.
I've created a very simple topology and configuration, MPLS, OSPF and BGP is working normally, but when I'm trying to redistribute connected or ospf 2 route-s to my vrf (hanssolo), I can't see the redistributed routes (neither OSPF, neither connected) in vrf routing table.
Do you have an idea or solution for this problem?
Is my configuration ok or I missed something? Or some XRv bug?
Config:
hostname R1
logging console debugging
vrf hanssolo
address-family ipv4 unicast
import route-target
1:4
export route-target
1:4
alias exec wrnet copy run harddisk:running-config
interface Loopback0
ipv4 address 1.1.1.1 255.255.255.255
interface MgmtEth0/0/CPU0/0
shutdown
interface GigabitEthernet0/0/0/0
description R2_fele
ipv4 address 10.0.0.1 255.255.255.0
interface GigabitEthernet0/0/0/1
description R4_fele
vrf hanssolo
ipv4 address 192.168.1.1 255.255.255.0
interface GigabitEthernet0/0/0/2
shutdown
router ospf 1
router-id 1.1.1.1
area 0
mpls ldp auto-config
interface Loopback0
passive disable
passive disable
router ospf 2
router-id 1.1.1.1
vrf hanssolo
redistribute bgp 1
area 2
passive disable
router bgp 1
address-family vpnv4 unicast
neighbor 3.3.3.3
remote-as 1
update-source Loopback0
vrf hanssolo
rd 1:4
mpls ldp
end
hostname R3
domain lookup disable
vrf hanssolo
import route-target
1:4
export route-target
1:4
interface Loopback0
ipv4 address 3.3.3.3 255.255.255.255
interface Loopback100
description teszt
ipv4 address 172.16.1.1 255.255.255.0
shutdown
ipv4 address 10.0.1.3 255.255.255.0
description R6_fele
vrf hanssolo
ipv4 address 192.168.2.3 255.255.255.0
shutdown
router ospf 1
router-id 3.3.3.3
area 0
interface Loopback0
passive disable
passive disable
router ospf 2
router-id 3.3.3.3
vrf hanssolo
redistribute bgp 1
area 2
passive disable
router bgp 1
neighbor 1.1.1.1
remote-as 1
vrf hanssolo
rd 1:4
mpls ldp
end
Thank you!
Richard Burts
I wonder about having both OSPF processes use the same router ID. I would suggest making each router ID unique. Also I suggest under router ospf add to the redistribute command the parameter subnets.
Rick
Rick
Hi Rick,
Thanks for your answer. I made some change in configuration, for example R1:
router bgp 1
 neighbor 3.3.3.3
  remote-as 1
vrf hanssolo
 rd 1:4
   redistribute ospf 2
router ospf 2
 vrf hanssolo
  router-id 192.168.1.1
  redistribute bgp 1
  area 0
    passive disable
R3 config is similar, but situation is not mutch better. I dont understand exactly what did you mean 'redistribute command the parameter subnets', because in XRv there aren't network command in ospf process (i can just change network type).
ps. Just for testing, I made this configuration with IOS and IOS-XE, and here redistributing working perfectly. So I think, I've missed someting from bgp or ospf configuration on XRv, or there are some kind of bug, and the redistribution will not work anyway.
Best regards,
neo
