IOS
justingorres
I'm trying to setup a test bed for callmanager 7 and the router I'm using for the network will not recognize any of the voice cards in the running config (as in, no dial-peers or voice ports.) I am running it's default IOS 12.4(3g) SPServices which we are using elsewhere just fine. I issue the "sh ver" command and I see that it recognizes that I have a 4 port FXO, 2-port FXS and a Channelized T1/PRI Controller card plugged in.
Sh Ver:
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FTX1233A42P
2 FastEthernet interfaces
1 Serial interface
1 Channelized T1/PRI port
4 Voice FXO interfaces
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Any ideas would be greatly appreciated!
5 Replies 5
Justin,
Please post a "sh diag" command.
To make sure that you have any PVDM installed on it.
Toshi
Test_Router#sh diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC12312FZM
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-04
Board Revision : A0
Deviation Number : 0
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20080731
Chassis Serial Number : FTX1233A42P
Chassis MAC Address : 0022.904c.9748
MAC Address block size : 24
CLEI Code : COM7R00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V05
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 32 33 31 32 46 5A 4D 40
0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 68 5B C2 8B 46 54 58 31 32 33 33
0x40: 41 34 32 50 C3 06 00 22 90 4C 97 48 43 00 18 C6
0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
WIC Slot 0:
2nd generation - FXS Voice daughter card (2 port)
Hardware Revision : 3.1
Top Assy. Part Number : 800-21341-01
Board Revision : E0
Deviation Number : 0-0
Fab Version : 01
PCB Serial Number : FOC093352D2
RMA History : 00
Product (FRU) Number : VIC2-2FXS=
0x00: 04 FF 40 00 47 41 03 01 C0 46 03 20 00 53 5D 01
0x10: 42 45 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 30
0x20: 39 33 33 35 32 44 32 03 00 81 00 00 00 00 04 00
0x30: 89 56 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision : 5.0
Top Assy. Part Number : 800-21589-02
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC10440M4U
RMA History : 00
Product (FRU) Number : VIC2-4FXO
Version Identifier : V01
CLEI Code : CNUIAPRAAA
0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 02
0x10: 42 41 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 30 34 34 30 4D 34 55 03 00 81 00 00 00 00 04 00
0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 31 20
0x40: C6 8A 43 4E 55 49 41 50 52 41 41 41 FF FF FF FF
WIC Slot 2:
FT1 PMC4351
Hardware Revision : 1.2
PCB Serial Number : FOC10505GXJ
Part Number : 73-8346-05
Board Revision : A0
RMA History : 00
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-03
CLEI Code : IPUIAPRRAA
0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 30 35
0x10: 30 35 47 58 4A 82 49 20 9A 05 42 41 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 57 49 43
0x30: 2D 31 44 53 55 2D 54 31 2D 56 32 20 20 20 20 20
0x40: 20 C0 46 03 20 00 56 B1 03 C6 8A 49 50 55 49 41
0x50: 50 52 52 41 41 FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 3:
T1 (1 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision D0
Serial number 30264715 Part number 800-03568-03
FRU Part Number VWIC-1MFT-T1=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 20 01 00 01 CD CD 8B 50 0D F0 03 00 00 00 00
0x30: 68 00 00 00 03 04 01 00 FF FF FF FF FF FF FF FF
Justin,
You need PVDM installed on it.
Do you have a CCO ID? If you do, please check this link.
http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
HTH,
Toshi
I feel partially dumb, ha. Thanks for your help.
