01-04-2017 10:43 PM - edited 03-05-2019 07:47 AM
IP address negotiated command not working on Cisco C841M-4X/K9 Router
When we configure ip address negotiate on Dialer 0 interface we are not able to get IP address
When we check show ip int brief Ip address is not assigned whereas when we remove Ip add negotiation command and enter Ip address manually then it works.
IOS version : c800-universalk9-mz.spa.155-1.t1.bin
01-04-2017 11:56 PM
try and add 'ppp ipcp accept-address' to the dialer interface configuration.
If that doesn't help, post the config of your router...
01-05-2017 02:42 AM
I have reset the dialer 0 interface to default and again reconfigured it and it started getting IP address.
Thank you everyone for you support.
01-05-2017 12:37 AM
Hello
Can you post the output from:
debug ppp negotiation
debug ppp authentication
res
Paul
