ip as-path access-list question
johnelliot6
Level 2
Level 2
Can someone please help me with an as-path acl regex?
We are peering with a customer, and accepting one(or more) of there AS's(Example below using AS "1234")
ip as-path access-list 30 permit ^1234(_1234)*$
The customer wants to start advertising a new range to us, and also a new AS (They are peering with there client)
So resultant AS path will be "1234 new_as"  (But can be any number of the 2 AS's, so could be "1234 1234 new_as new_as" etc)
Hope someone can assist
Cheers
7 Replies 7
Abzal
Level 7
Level 7
Configuration seems ok. Either you can use:
ip as-path access-list 30 permit ^1234(_[0-9]+)+$
http://blog.ine.com/tag/as-path/
Abzal
Best regards,
Abzal
Thanks - So to permit AS 1234 and 5678 (And any number of prepends), I could use:
^(_1234)+(_5678)$
It really depends
if it is learned from AS1234 and next will be AS5678 (plus one or more prepends) then:
^1234(_5678)+$         --> e.g   AS 1234 -----  AS 5678 -----  AS 5678(one or more) ---- your AS
^(1234)+(_5678)+$                 AS 1234  ----   AS 1234(one or more)  ----  AS 5678 ----  AS 5678(one or more) --- your AS
If these ASes located along the path:
^([0-9]+)+(_1234)+(_5678)+$
Above link is very useful have a look on it.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Thanks very much Abzal - much appreciated.
To confirm, the regex:
^(1234)+(_5678)+$
would match AS paths such as:
1234
1234 1234
1234 5678
1234 5678 5678
Or would it also require a "_" in front of 1234?(To match one or more "1234")  i.e.
^(_1234)+(_5678)+$
I've just tested it and required result gave only this access-list
^(1234)(_[1-4]+)?(_5678)?(_[5-8]+)?$
it will match
1234
1234 1234
1234 5678
1234 1234 5678
1234 1234 5678 5678
1234 5678 5678
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
[1-4]+  is not what you want, it matches 11, 111, 1113, 3322 etc. so any number of repetitions of any digits in the 1,2,3,4 interval
I would write
ip as-path access-list 30 permit ^1234(_1234)*(_5678)*$
HI,
why do we using as-path attributes ? can anyone explain.
