IP Based QOS
imran.moulvi
Level 2
Level 2
Hi Experts,
Is there a way to restrict bandwidth per IP.
I mean, to allow each IP in a network to use only a defined amount of bandwidth, say 64 Kbps at any time.
Joseph W. Doherty
On many devices you could target a policer for a specific IP address, but if many, becomes difficult to maintain and depending on device, might be limited in number of individual policers you can implement.
On the 6500 series, believe they have something called a microflow policer that might lend itself to such an application without needing to predefine every individual IP address.
tcordier
Level 5
Level 5
You can achieve this using MQC policing or CAR. Here are two configurations which show how you could achieve this, for each of the two methods:
1st method MQC:
Define your source IP addresses:
ip access-list standard IP_1
permit 1.1.1.1
ip access-list standard IP_2
permit 2.2.2.2
Define the traffic classes using these ACLs:
class-map match-all IP_1
match access-group name IP_1
class-map match-all IP_2
match access-group name IP_2
Define the policy:
policy-map Police
class IP_1
police 64000
class IP_2
police 64000
-> This will police the traffic in each class to 64K, and drop all traffic above this threshold.
Apply the policy:
interface xyz
service-policy output Police
2nd Method CAR:
interface xyz
rate-limit output access-group 1 64000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 2 64000 8000 8000 conform-action transmit exceed-action drop
For both methods you have many additional options about how to handle exceeding traffic, or how to specify traffic in different ways, such as for destination IP addresses, protocols etc.
Check http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/12_4/qos_12_4_book.html for more information and details.
HTH, Thomas
