IP datagram Header
Ahmed Malik
Level 3
Level 3
In the IP datagram header which is of 32 bytes there is this one variable field known as "option and Padding". i want to know what kind of options are included in this header.
Ahmed
andrew.prince
Level 11
Level 11
Read the below URL - it will tell you everything you need to know
http://www.faqs.org/rfcs/rfc791.html
HTH>
andrew.prince
Level 11
Level 11
HTH>
