IP loopback
webstd.design
When should I use "interface Loopback"?
Why it is used on the routers?
5 Replies 5
garytayl
Level 3
Level 3
HI, [Pls RATE if HELPS]
Refer the link below, having the details about the earlier POST that was answered:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&topicID=.ee71a04&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc0652d
PLS RATE if HELPS
Best Regards,
Guru Prasad R
sdoremus33
Level 3
Level 3
Loopback interfaces are virtual interfaces and therefore are not succeptable to hw failure. also I use Loopbacks in OSPF evnironments for router identifier
Ex:
interface loopback0
ip address x.x.x.x. y.y.y.y
router ospf
router-id x.x.x.x. where x.x.x.x is the loopback0 interface created. HTH
Ex:
interface loopback0
router ospf
Any body can say some example like this?
Goutam Sanyal
Level 4
Level 4
Hi Alexandr Kulbida,
Loopback interface can be used for OSPF, IPSLA, SNMP TRAP, NTP etc.
More details: http://en.wikipedia.org/wiki/Loopback
Goutam
