07-30-2008 01:07 AM - edited 03-03-2019 10:57 PM
Hi all,
Just getting to grips with OSPF for my CCNA. I have a question which I'm sure most of you will be able to answer easily.
On an Area Border Router when configuring 'network 172.16.0.1 0.0.0.0 area 0 and network 192.168.0.1 0.0.0.0 area 1, can both lines be configured under the same OSPF process ID, ie 'router ospf 1'? Or when configuring 2 OSPF areas, does that router need 2 OSPF processes running?
Thanks all,
Garry
07-30-2008 01:18 AM
You just use the single ospf process id, and put all your network statements in there.
LR
07-30-2008 01:31 AM
Thanks Lee! I was just wondering because of the 2 Areas.
07-30-2008 03:41 AM
You may run multiple OSPF processes on a single router, but take note that it creates multiple database instances that add extra overhead to the router.
07-30-2008 03:43 AM
Ok have done! thanks.
