IP NAT on 7206
bradlesliect
How do you enable NAT or get it to work on a cisco 7206VXR Router?
IOS: c7200-p-mz.123-20.bin
I have client interfaces that I need to configure with NAT statements on it.
Brad
9 Replies 9
mohammedmahmoud
Level 11
Level 11
In brief:
interface serial 0/0.1 point-to-point
description Connected to Internet
ip nat outside
interface fastethernet 0/0
description Connected to LAN
ip nat inside
ip nat inside source list 10 interface serial0/0.1 overload
or
ip nat pool test-pool prefix
ip nat inside source list 10 pool test-pool
access-list 10 permit
For more details:
http://www.cisco.com/en/US/tech/tk648/tk361/tk438/tsd_technology_support_sub-protocol_home.html
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Hi Mohammed,
The router is not accepting ANY of the NAT commands.
I tried just putting in 'ip nat inside source ....' and this is not working.
The only thing I can type is 'ip name-server....' there IS NO 'ip nat' command
I am sorry, your IOS seems to be an IP-Base and i think that it doesn't support NAT, try upgrading it.
you can use Cisco Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Mohammed Mahmoud.
Hey there,
Help me out here. I am finding it difficult using the feature navigator. Which IOS for the 7206 was released after the one I am currently using which will support NAT?
Go to the above link and click search by feature, then from the available features choose "NAT - Network Address Translation", and click Add then click continue, then choose your platform "7200" and choose 12.3 for the Major Release, and here you are you'll get all the IOSs that support NAT for your platform.
Mohammed Mahmoud.
For this flavor of NAT (Dynamic or Static), How much is
  • Max throughput value
  • Max number Translation per second
Thanks in advance
Ryan
If I were you, I would have been using 12.3T with IP PLUS feature set as it gives you and IOS with a lot of features (BGP, NAT etc)
Hope this helps,
Please rate,
Kind Regards,
Wilson Samuel
I have a 128MB flash in disk 0 on this router. Can I load the new image on the same flash and have the boot statements configured to boot off either of the images
Currently the statement reads:
boot system flash disk0:c7200-p-mz.123-20.bin
Can I change it to:
boot system flash disk0:c7200-is-mz.123-22.bin
Yes you can use multiple boot statements, and they are executed sequentially, if one fails the other is processed, and as long as the first image is valid it will always be used.
Mohammed Mahmoud.
