ip nat problem
hi all,
I use a Cisco router, my computer Server can't connect to the internet. the router gets an IP address from the firewall as dhcp, From the router, I can also ping ip dns. but can't ping the domain name server.
below is my Cisco "show run"
Router
Building configuration...
Current configuration : 3025 bytes
cwmp
vlan 1
vlan 10
 name VLAN-MGMT
vlan 16
 name VLAN_DMZ
vlan 20
 name VLAN-WIFI
service dhcp
ip dhcp excluded-address 192.168.10.1 192.168.10.9
ip dhcp excluded-address 192.168.20.1 192.168.20.9
ip dhcp excluded-address 172.16.10.1 172.16.10.9
ip dhcp pool User_Pool
 network 192.168.10.0 255.255.255.0
 dns-server 8.8.8.8
 default-router 192.168.10.1
ip dhcp pool User_Pool_20
 network 192.168.20.0 255.255.255.0
 dns-server 8.8.8.8
 default-router 192.168.20.1
ip dhcp pool DMZ_Pool
 network 172.16.10.0 255.255.255.0
 dns-server 8.8.8.8
 default-router 172.16.10.1
control-plane
control-plane protocol
 acpp bw-rate 1250 bw-burst-rate 2500
control-plane manage
 port-filter
 arp-car 5
control-plane data
 glean-car 5
enable secret 5 $1$mniP$pC9F4FzyuA3Dxyvx
enable service web-server http
enable service web-server https
interface GigabitEthernet 0/0
 ip nat outside
 ip address dhcp
 duplex auto
 speed auto
interface GigabitEthernet 0/1
 duplex auto
 speed auto
interface GigabitEthernet 0/2
 duplex auto
 speed auto
interface GigabitEthernet 0/3
 duplex auto
 speed auto
interface GigabitEthernet 1/0
interface GigabitEthernet 1/1
 switchport mode trunk
interface GigabitEthernet 1/2
interface GigabitEthernet 1/3
interface GigabitEthernet 1/4
interface GigabitEthernet 1/5
interface GigabitEthernet 1/6
interface GigabitEthernet 1/7
interface GigabitEthernet 1/8
interface GigabitEthernet 1/9
interface GigabitEthernet 1/10
interface GigabitEthernet 1/11
interface GigabitEthernet 1/12
interface GigabitEthernet 1/13
interface GigabitEthernet 1/14
interface GigabitEthernet 1/15
interface GigabitEthernet 1/16
interface GigabitEthernet 1/17
interface GigabitEthernet 1/18
interface GigabitEthernet 1/19
interface GigabitEthernet 1/20
interface GigabitEthernet 1/21
interface GigabitEthernet 1/22
interface GigabitEthernet 1/23
interface VLAN 1
interface VLAN 10
 ip nat inside
 ip address 192.168.10.1 255.255.255.0
interface VLAN 16
 ip nat inside
 ip address 172.16.10.1 255.255.255.0
interface VLAN 20
 ip nat inside
 ip address 192.168.20.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.1.1.1
end
switch-1
Current configuration: 2524 bytes
no spanning-tree
cwmp
sysmac 0074.9c14.605f
nfpp
redundancy
no zam
vlan 10
 name VLAN_MGMT
vlan 16
 name VLAN_DMZ
vlan 20
 name VLAN-WIFI
vlan 1
 switchport access vlan 10
 poe enable
 poe enable
 poe enable
interface GigabitEthernet 0/4
 poe enable
interface GigabitEthernet 0/5
 poe enable
interface GigabitEthernet 0/6
 poe enable
interface GigabitEthernet 0/7
 poe enable
interface GigabitEthernet 0/8
 poe enable
interface GigabitEthernet 0/9
 poe enable
interface GigabitEthernet 0/10
 poe enable
interface GigabitEthernet 0/11
 poe enable
interface GigabitEthernet 0/12
 poe enable
interface GigabitEthernet 0/13
 poe enable
interface GigabitEthernet 0/14
 poe enable
interface GigabitEthernet 0/15
 poe enable
interface GigabitEthernet 0/16
 poe enable
interface GigabitEthernet 0/17
 poe enable
interface GigabitEthernet 0/18
 poe enable
interface GigabitEthernet 0/19
 poe enable
interface GigabitEthernet 0/20
 poe enable
interface GigabitEthernet 0/21
 switchport access vlan 20
 poe enable
interface GigabitEthernet 0/22
 poe enable
interface GigabitEthernet 0/23
 switchport access vlan 16
 poe enable
interface GigabitEthernet 0/24
 poe enable
interface TenGigabitEthernet 0/25
interface TenGigabitEthernet 0/26
interface TenGigabitEthernet 0/27
interface TenGigabitEthernet 0/28
interface VLAN 10
 ip address 192.168.10.2 255.255.255.0
interface VLAN 16
 ip address 172.16.10.3 255.255.255.0
interface VLAN 20
 ip address 192.168.20.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.20.1
line console 0
line vty 0 4
 login
end
SWITCH-2
Current configuration: 2340 bytes
no spanning-tree
cwmp
sysmac 0074.9c71.70cf
nfpp
redundancy
no zam
vlan 16
 name DMZ
vlan 1
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
 poe enable
interface VLAN 16
 ip address 172.16.10.4 255.255.255.0
ip route 0.0.0.0 0.0.0.0 172.16.10.1
line console 0
line vty 0 4
 login
end
thanks for your reply.
2 Accepted Solutions
Seb Rupik
Hi there,
firstly try adding the following config to the router:
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip access-list standard NAT
 permit 192.168.1.0 0.0.0.255
 permit 192.168.10.0 0.0.0.255
 permit 172.16.10.0 0.0.0.255
 permit 192.168.20.0 0.0.0.255
What device is 10.1.1.1 ?
cheers,
Seb.
Hello
You dont require L3 interface on all 3 devcies, having them just on the router would be fine
So remove the L3 addressing/ip routing from the switchs apart from the mgt vlan interface and just have them run as host switches with a default gateway pointing rtrs L3 address of the mgt vlan.
The trunks between the two switchs need to alow all applicable vlans to travesre their interconnect and so does the trunk from the switch towards the router.
On the router make the follwoing changes:
conf t
no ip route 0.0.0.0 0.0.0.0 10.1.1.1
ip route 0.0.0.0 0.0.0.0 gig0/0 dhcp
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 1 permit 172.16.10.0 0.0.0.255
ip nat inside source list 1 interface gig0/0
Kind Regards
Paul
7 Replies 7
Seb Rupik
Hi there,
cheers,
Seb.
Thank you, your solution works for me. Now, my computer server can access the internet.
but what interface is used on the firewall to allow traffic from WAN to LAN
as an example:
xxx.xxx.xxx.xx:443 is directed to the computer server's ip address 172.16.10.12:443
thanks.
Try:
ip nat inside source static tcp 172.16.10.12 443 interface gi0/0 443 ext
cheers,
Seb.
hi, i'm trying
I got this:
% Invalid input detected at '^' marker.
the 'extendable' keyword is not suppported when you use the syntax you have posted. What are you trying to accomplish ?
I want to access the computer server from WAN, as example:
xxxx.xxx.xxx.xx:8080 directed to the private ip address 172.16.10.10 on port 443
detailed in this forum:
https://community.spiceworks.com/topic/2254023-failed-to-access-lan-on-port-80-of-wan
thank you.
Hello
conf t
Kind Regards
Paul
