04-05-2017 05:00 AM - edited 03-05-2019 08:18 AM
I can't set the ip policy route-map in a cisco Switch C3560X-24P-L.
Someone know why please ?
Best regards,
Rim
04-05-2017 05:10 AM
You need IP Services feature set and you need to enable the SDM routing template.
Jon
04-05-2017 06:37 AM
Hey Joh,
The SDM Routing is already enabled.
#show sdm prefer
The current template is "desktop routing" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 3K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 11K
number of directly-connected IPv4 hosts: 3K
number of indirect IPv4 routes: 8K
number of IPv4 policy based routing aces: 0.5K
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 1K
Concrening the Ip services what is the feature that I should have?
Thank you for your help,
Rim
04-05-2017 07:09 AM
Please check these links:
http://www.booches.nl/2008/06/policy-based-routing-catalyst-3560/
https://supportforums.cisco.com/blog/149901/pbr-switches-37503560
The following link could be useful to determinate if your IOS support PBR:
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
Could you please share the error message?
04-05-2017 07:15 AM
I don't have the error message, the problem is that I can't add " ip policy route-map" under the interface. is like it doesn't exist.
Rim
04-05-2017 07:37 AM
Are you appying that under the SVI or layer 3 port? is ip routing command enabled?
interface vlan 100
ip add 192.168.100.1 255.255.255.0
ip policy route-map TEST
or
interface g1/1
no switchport
it will not work under layer 2 interfaces.
04-05-2017 07:44 AM
Hey,
I'm trying to apply it under SVI like:
interface vlan 100
I checked in this link http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp if my IOS support the PRB and it's ok:
please see the attached pecture
04-05-2017 07:52 AM
Hey,
No I did a mistake my SW image is:
Switch Ports Model SW Version SW Image
* 1 30 WS-C3560X-24P 15.0(1)SE3 C3560E-UNIVERSALK9NPE-M
What I have checked in the mail before was the 15.0(2).
So, for 15.0(1) I don't find the SW image UNIVERSALK9NPE that I have in my switch.
Rim
04-05-2017 08:57 AM
You need this IOS
| 15.0SE | 15.0(1)SE3 | ED | No | CAT3560X | UNIVERSAL (IP SERVICES) | 128 | 64 | No | c3560e-universalk9-mz.150-1.SE3.bin |
15.0SE 15.0(1)SE3 ED No
CAT3560X UNIVERSAL (IP SERVICES) 128 64 No
04-06-2017 12:41 AM
I've changed the SW Image by c3560e-universalk9-mz.150-1.SE3.bin but I still have the same problem :(.
Rim
04-06-2017 05:27 AM
Is the SDM routing template enabled?
04-06-2017 05:32 AM
Yes.
Switch#show sdm prefer
number of IPv4 unicast routes: 10.875k
number of indirect IPv4 routes: 7.875k
number of IPv6 multicast groups: 64
number of IPv6 unicast routes: 32
number of directly-connected IPv6 addresses: 0
number of indirect IPv6 unicast routes: 32
number of IPv4/MAC qos aces: 0.375k
number of IPv4/MAC security aces: 0.875k
number of IPv6 policy based routing aces: 0
number of IPv6 qos aces: 0
number of IPv6 security aces: 58
