'ip routing' command on a layer 2 switch
amai_yuki
Community Member
our company is currently converting multiple branches to cisco devices. I got a little problem on one of the switch(3750), I can telnet and ping the switch from the router, but not from the management PC, when I compare the basic config handed by our ISP on two switches, I found the 'ip routing' command is configured on the switch in problem, after this command removed, everything works fine. I'm wondering if anyone could tell me how/why this command causes the above problem.
appreciate your help!
Richard Burts
Amai
Based on your description of the problem I am guessing that the switch was configured with ip default-gateway. This works on layer 2 devices to define the default gateway which the device will use to get to any remote destination. However if ip routing is enabled then the device is operating as a layer 3 device and will not use the default-gateway. As a layer 3 device it would need dynamic routes from a routing protocol, or static routes (including a configured default route) to get to remote destinations.
While the ip default-gateway will be retained in the configuration the only time that it will be used is when ip routing is disabled.
Rick
Rick
OR
1. enable ip routing
2. configure ip route 0.0.0.0 0.0.0.0 instead of ip default-gateway
basically it's a router without any ip routing protocols enabled.
