IP RTP COMPRESSION
patcbr600
I have configured ip rtp header compression on my network:
This is the output from the show command:
CE-CF-Aveiro#sh ip rtp header-compression multilink 1
RTP/UDP/IP header compression statistics:
We're compressing using MQC profiles, use the
MQC commands to see the stats for each class.
Interface Multilink1 (compression on, IPHC, RTP)
Rcvd: 335407 total, 333223 compressed, 0 errors, 0 status msgs
0 dropped, 0 buffer copies, 0 buffer failures
Sent: 381379 total, 376798 compressed, 0 status msgs, 183167 not predicted
12609923 bytes saved, 10791795 bytes sent
2.16 efficiency improvement factor
Connect: 64 rx slots, 64 tx slots,
757 misses, 2 collisions, 0 negative cache hits, 64 free contexts
99% hit ratio, five minute miss rate 0 misses/sec, 0 max
Does any one know what is the meaning of : 183167 not predicted
Thanks.
thisisshanky
Level 11
Level 11
Do you have an RSVP enabled ? If not I guess those numbers relate to those packets which were not compressed using RSVP Predicted compression.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_white_paper09186a00801541cc.shtml
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I dont have rsvp enable , on a document i read that not predicted packets are packets that take a non optimal path true the compressed.
