IP sec issue
arupbiet2006
hi all,
i had configure ip sec but link can't up so,could you help me to configure ipsee
9 Replies 9
satish_zanjurne
Level 4
Level 4
1.Don't start with IPSec configuration directly.
2.First see the whether link is up between peers & peer can ping each other.
3.Use show interface to see the interface status..
HTH..rate if helpful..
hello...every thing is ok...could u send me a ip sec config
1.tell me on which devices you are trying to establish the IPsec ??
ip sec between router to router
First Router Config
hostname R2
crypto isakmp policy 10
authentication pre-share
crypto isakmp key ciscokey address 200.1.1.1
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map myvpn 10 ipsec-isakmp
set peer 200.1.1.1
set transform-set myset
!--- Include the private-network-to-private-network traffic
!--- in the encryption process:
match address 101
interface Ethernet0/0
description------LAN Interface-----
ip address 172.16.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Ethernet1/0
description----WAN interface where other peer is connected---
ip address 100.1.1.1 255.255.255.0
ip nat outside
crypto map myvpn
ip route 0.0.0.0 0.0.0.0 100.1.1.254
!--- Except the private network from the NAT process:
ip nat inside source list 175 interface Ethernet1/0 overload
access-list 101 permit ip 172.16.1.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 175 deny ip 172.16.1.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 175 permit ip 172.16.1.0 0.0.0.255 any
--------------------------------------------Router R3
hostname R3
crypto isakmp key ciscokey address 100.1.1.1
set peer 100.1.1.1
match address 101
descrption-----LAN Interface----
ip address 10.1.1.1 255.255.255.0
ip nat inside
description---WAN Interface
ip address 200.1.1.1 255.255.255.0
ip nat outside
crypto map myvpn
ip route 0.0.0.0 0.0.0.0 200.1.1.254
ip nat inside source list 122 interface Ethernet1/0 overload
!--- Except the static-NAT traffic from the NAT process if destined
!--- over the encrypted tunnel:
access-list 101 permit ip 10.1.1.0 0.0.0.255 172.16.1.0 0.0.0.255
access-list 122 deny ip 10.1.1.0 0.0.0.255 172.16.1.0 0.0.0.255
access-list 122 permit ip 10.1.1.0 0.0.0.255 any
HTH...rate if helpful...
Make sure you are adding proper default routes..
when i prompt crypto ipsec transform-set command then i can't enter this myset esp-3des esp-md5-hmac
hi,
myset is the name of transform set, so you need to type it as it is. It is not the keyword, but esp-3des & esp-md5-hmac are keyword, you can get this by using "?" or pressing tab.
Thank you satish.
