IP sla and HSRP help
Gerard Roy
Level 2
Level 2
Hi all,
I have a scenario where I need to see how others have accomplished the following. I have two 3925 Head Ends and have 2 ISP's. I need to fail over to the secondary ISP if the primary is down and fail over to the secondary Head End if the Primary Head end goes down or is inaccessible.
I can get the Primary Head End (HE) to fail between the two ISP's using IP sla but having trouble failing to the secondary HE and getting all interfaces to go into standby. The secondary HE has an IP in the same subnet on both (two) WAN interfaces (both are using a VIP) and also on the LAN using a VIP.
Anyone have a similar scenario?
Thanks!
Amit Goyal
Hi Gerard,
Sorry to bother you but i am not able to understand your topology. Could you please attach a simple drawing and your requirement again?
-Amit
Sterilized version
sathish.ippani
You can use track and decrement command in HSRP to fail over
