Showing results forĀ
Search instead forĀ
Did you mean:Ā
IP SLA design
The_guroo_2
Level 2
Level 2
We have two data centres  A and B
Both are same in design
Datacentre A:
WAN router is connected to ------firewall-------firewall has many DMZ switches----------firewall internal interface is connected to core switch.....the core switch is connected to datacentre B via fibre and running OSPF (same vlan spanned)
Datacentre B:
Same as datacentre A
Design for high availability:
In datacentre A I am thinking that i would add a default static route pointing towards firewall internal interface on firewall.
I will add IP SLA and will ping the interface of provider router on WAN as soon as it fails, IP SLA will install a static route towards the second daatcentre internal firewall interface.
Is this a good design????
Do i have to add any Static routing on datacentre B???
this is tarffic going out for in traffic we will use BGP with service provider
please advise
Julio Carvajal
A draw could be way better for us to provide you a better design.
I would not want to provide any response yet until I have a better description of the network setup.
Then I will let you know where to set the SLA and how to do it if you allow me
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
