IP SLA with loopback
Rizwan Khan
Hi all,
I am facing issue with using IP SLA, i am given a project in office and need to implement policy based routing,
for some reasons i want to use loopback for it.
I have 2 routers A and B
i just want if traffic from 216.0 network comes on A set next hop to routers B looback interface. Can i do it? its working fine with physical interfaces but not with loop back. This loop back is reacible and from router A if i telnet the loopback IP of B it actually gets me to Router B as well. PLease i need urgent advise. Thanks in advance.
Simon Brooks
Show me your ip route commands as well as the interface configs pls. My guess is you need a recursive route to point anything destined for the loopback to the actual next hop. The loopback wont be the next hop will it. Its actually 2 hops away!
I need to see the point to point interface configs. The loopback config and the ip route statements but I suspect im correct
Sent from Cisco Technical Support Android App
Simon Brooks
Hi simon,
Yeah you are absolutely right that was the actual problem, it was not setting nexthop cause that loopback in not directly connected. Thank you so much.
Simon Brooks
You're welcome.
