ip verify unicast source reachable-via rx For BGP
johnlloyd_13
Level 9
Level 9
hi all,
i've ran into an issue on one of our EBGP peer and discovered the command "ip verify unicast source reachable-via rx" blocked their incoming traffic when their prefix is not advertised to us.
#sh run int vl473
Building configuration...
Current configuration : 257 bytes
interface Vlan473
ip address 203.x.x.x 255.255.255.252
ip verify unicast source reachable-via rx   >>>
ip flow ingress
service-policy input INGRESS-45M
service-policy output EGRESS-45M
end
i've found the link below but i would appreciate if someone could explain it how it relates to BGP. thanks in advance!
http://www.cisco.com/web/about/security/intelligence/unicast-rpf.html
Richard Burts
John
I do not believe that Reverse Path Forwarding check relates specifically to BGP. What it does is to make sure that packets received on an interface are not "spoofed" and it does this by checking to see if the path to the source address does use this interface as the way to get to that source network. From what you are describing the source address of the BGP peer is through that interface but not in the connected subnet. Is that correct?
So what is happening seems to be that the RPF check is denying their traffic when their prefix is not advertised to you. And if their traffic is being denied then they can not establish the neighbor relationship that is necessary to advertise their prefix to you.
In most implementations of RFP there is an option to use an access list in the command. The access list gives exceptions which should be allowed even if they fail the RPF check. That would seem to be the best solution if it is available in your version of code.
Rick
Rick
Richard Burts
John
Rick
Rick
hi rick,
thanks for your feedback! yes, what you've described is exactly correct.
i also believe it has nothing to do with BGP. probably this command line is some sort of anti-spoof or security feature.
i'll consider tagging an ACL for this.
Allow ip or just icmp  from your source address,  create a acl as Richard suggests.
access-list 101 permit ip ( source ip + wildcard mask ) any
                                     or
access-list 101 permit icmp ( source ip + wildcard mask ) any
interface Vlan473
ip verify unicast source reachable rx 101
res
Paul
Kind Regards
Paul
