05-01-2019 02:23 AM
Hi all,
Sorry if this is the wrong place for this question. Im new to stackoverflow.
I'm trying to follow a guide for HA on azure but im falling at the first hurdle.
The youtube video links are expired so i had to fill the gaps on the config and may have made a mistake.
Here is the video which has some diagrams.
Basically my ipsec tunnel will not establish between two routers.
Config from RTR1:
crypto ikev2 proposal azure-proposal encryption aes-cbc-256 aes-cbc-128 3des integrity sha1 group 2 ! crypto ikev2 policy azure-policy proposal azure-proposal ! crypto ikev2 keyring ONE peer 20.39.208.39 address 20.39.208.39 pre-shared-key cisco123 ! ! crypto ikev2 profile ONE match identity remote address 20.39.208.39 255.255.255.255 (also tried any) authentication remote pre-share authentication local pre-share keyring local ONE ! ! crypto ipsec transform-set azure-ipsec-proposal-set esp-aes 256 esp-sha-hmac mode tunnel ! crypto ipsec profile ONE set transform-set azure-ipsec-proposal-set set ikev2-profile ONE ! interface Loopback0 ip address 10.255.3.1 255.255.255.255 ! interface Tunnel1 description to ONE ip unnumbered Loopback0 ip tcp adjust-mss 1350 tunnel source 51.143.190.207 (tried both the interface and the IP) tunnel mode ipsec ipv4 tunnel destination 20.39.208.39 tunnel protection ipsec profile ONE ! interface GigabitEthernet1 ip address dhcp negotiation auto !
Config from RTR2:
crypto ikev2 proposal azure-proposal encryption aes-cbc-256 aes-cbc-128 3des integrity sha1 group 2 ! crypto ikev2 policy azure-policy proposal azure-proposal ! crypto ikev2 keyring ONPREM peer 51.143.190.207 address 51.143.190.207 pre-shared-key cisco123 ! ! crypto ikev2 profile ONPREM match identity remote address 51.143.190.207 255.255.255.255 authentication remote pre-share authentication local pre-share keyring local ONPREM ! ! crypto ipsec transform-set azure-ipsec-proposal-set esp-aes 256 esp-sha-hmac mode tunnel ! crypto ipsec profile ONPREM set transform-set azure-ipsec-proposal-set set ikev2-profile ONPREM ! ! interface Loopback0 ip address 10.255.1.1 255.255.255.255 ! interface Tunnel1 description to ONPREM ip unnumbered Loopback0 ip tcp adjust-mss 1350 tunnel source 20.39.208.39 tunnel mode ipsec ipv4 tunnel destination 51.143.190.207 tunnel protection ipsec profile ONPREM ! interface GigabitEthernet1 ip address dhcp negotiation auto !
I used debug crypto isakmp and ipsec and the only error i saw was
"peer matches *none* of the profiles" which is why i tried "match identity any" but get the same result.
I have full connectivity between the routers and and ping and telnet between them on the relevant ports.
Any help will be appreciated.
Rik
05-01-2019 03:08 AM
at first glance you are missing the line marked in bold:
match address local interface <NameOfYourOutsideInterface>
keyring local ONE
Also, what routing and what access lists do you have configured ? Post the entire running configs of both sides if possible...
05-02-2019 02:19 AM
Thanks for the suggestion.
I added the config below but im getting the same result.
crypto ikev2 profile ONE match address local interface GigabitEthernet1
Im wondering if the issue is that Azure routers grab the private ip for each interface which they then nat behind an Azure public so its not matching as its seeing a tunnel packet coming from a public IP.
See the debug here
CISCO-ONPREM#debug crypto isakmp Crypto ISAKMP debugging is on CISCO-ONPREM#debug crypto ipsec Crypto IPSEC debugging is on CISCO-ONPREM#ter mon CISCO-ONPREM# *May 2 09:08:53.667: ISAKMP: (0):peer matches *none* of the profiles *May 2 09:08:57.848: IPSEC:(SESSION ID = 4158) (key_engine) request timer fired: count = 1, (identity) local= 10.0.0.4:0, remote= 20.39.208.39:0, local_proxy= 0.0.0.0/0.0.0.0/256/0, remote_proxy= 0.0.0.0/0.0.0.0/256/0 *May 2 09:08:57.848: IPSEC(sa_request): , (key eng. msg.) OUTBOUND local= 10.0.0.4:500, remote= 20.39.208.39:500, local_proxy= 0.0.0.0/0.0.0.0/256/0, remote_proxy= 0.0.0.0/0.0.0.0/256/0, protocol= ESP, transform= esp-aes 256 esp-sha-hmac (Tunnel), lifedur= 3600s and 4608000kb, spi= 0x0(0), conn_id= 0, keysize= 256, flags= 0x0 *May 2 09:09:01.457: ISAKMP: (0):peer matches *none* of the profiles *May 2 09:09:15.993: IPSEC(sa_request): , (key eng. msg.) OUTBOUND local= 10.0.0.4:500, remote= 40.81.144.77:500, local_proxy= 0.0.0.0/0.0.0.0/256/0, remote_proxy= 0.0.0.0/0.0.0.0/256/0, protocol= ESP, transform= esp-aes 256 esp-sha-hmac (Tunnel), lifedur= 3600s and 4608000kb, spi= 0x0(0), conn_id= 0, keysize= 256, flags= 0x0 *May 2 09:09:23.666: ISAKMP: (0):peer matches *none* of the profiles CISCO-ONPREM# *May 2 09:09:27.848: IPSEC:(SESSION ID = 4158) (key_engine) request timer fired: count = 2, (identity) local= 10.0.0.4:0, remote= 20.39.208.39:0, local_proxy= 0.0.0.0/0.0.0.0/256/0, remote_proxy= 0.0.0.0/0.0.0.0/256/0 *May 2 09:09:27.848: IPSEC(sa_request): , (key eng. msg.) OUTBOUND local= 10.0.0.4:500, remote= 20.39.208.39:500, local_proxy= 0.0.0.0/0.0.0.0/256/0, remote_proxy= 0.0.0.0/0.0.0.0/256/0, protocol= ESP, transform= esp-aes 256 esp-sha-hmac (Tunnel), lifedur= 3600s and 4608000kb, spi= 0x0(0), conn_id= 0, keysize= 256, flags= 0x0un all All possible debugging has been turned off
Here is the full config from each side:
ONPREM
version 16.10 service timestamps debug datetime msec service timestamps log datetime msec platform qfp utilization monitor load 80 no platform punt-keepalive disable-kernel-core platform console serial ! hostname CISCO-ONPREM ! boot-start-marker boot-end-marker ! ! vrf definition GS rd 100:100 ! address-family ipv4 exit-address-family ! logging persistent size 1000000 filesize 8192 immediate ! aaa new-model ! ! aaa authentication login default local aaa authorization exec default local none ! ! ! ! ! aaa session-id common ! ! ! ! ! ! ! ip domain name ***** ! ! ! login on-success log ! ! ! ! ! ! ! subscriber templating ! ! ! ! ! multilink bundle-name authenticated ! ! ! license udi pid CSR1000V sn ***** no license smart enable diagnostic bootup level minimal ! ! ! username ***** ! redundancy ! crypto ikev2 proposal azure-proposal encryption aes-cbc-256 aes-cbc-128 3des integrity sha1 group 2 ! crypto ikev2 policy azure-policy proposal azure-proposal ! crypto ikev2 keyring ONE peer 20.39.208.39 address 20.39.208.39 pre-shared-key ***** ! ! crypto ikev2 keyring TWO peer 40.81.144.77 address 40.81.144.77 pre-shared-key ***** ! ! ! crypto ikev2 profile ONE match address local interface GigabitEthernet1 match identity remote address 20.39.208.39 255.255.255.255 authentication remote pre-share authentication local pre-share keyring local ONE ! crypto ikev2 profile TWO match address local interface GigabitEthernet1 match identity remote address 40.81.144.77 255.255.255.255 authentication remote pre-share authentication local pre-share keyring local TWO ! ! ! ! ! ! ! ! ! ! ! ! crypto ipsec transform-set azure-ipsec-proposal-set esp-aes 256 esp-sha-hmac mode tunnel ! crypto ipsec profile ONE set transform-set azure-ipsec-proposal-set set ikev2-profile ONE ! crypto ipsec profile TWO set transform-set azure-ipsec-proposal-set set ikev2-profile TWO ! ! ! ! ! ! ! ! ! ! interface Loopback0 ip address 10.255.3.1 255.255.255.255 ! interface Loopback1 ip address 10.255.3.2 255.255.255.255 ! interface Tunnel1 description to ONE ip unnumbered Loopback0 ip tcp adjust-mss 1350 tunnel source GigabitEthernet1 tunnel mode ipsec ipv4 tunnel destination 20.39.208.39 tunnel protection ipsec profile ONE ! interface Tunnel2 description to TWO ip unnumbered Loopback1 ip tcp adjust-mss 1350 tunnel source GigabitEthernet1 tunnel mode ipsec ipv4 tunnel destination 40.81.144.77 tunnel protection ipsec profile TWO ! interface GigabitEthernet1 ip address dhcp negotiation auto ! router bgp 65000 bgp log-neighbor-changes bgp bestpath as-path multipath-relax neighbor 10.255.1.1 remote-as 65001 neighbor 10.255.1.1 ebgp-multihop 3 neighbor 10.255.1.1 update-source Loopback0 neighbor 10.255.2.1 remote-as 65002 neighbor 10.255.2.1 ebgp-multihop 3 neighbor 10.255.2.1 update-source Loopback1 ! address-family ipv4 network 10.0.1.0 mask 255.255.255.0 neighbor 10.255.1.1 activate neighbor 10.255.1.1 route-map bgp out neighbor 10.255.2.1 activate neighbor 10.255.2.1 route-map bgp out maximum-paths 16 exit-address-family ! ip forward-protocol nd no ip http server ip http secure-server ip route 10.255.1.1 255.255.255.255 Tunnel1 ip route 10.255.2.1 255.255.255.255 Tunnel2 ! ip ssh rsa keypair-name sshkeys ! ! ip prefix-list bgp seq 5 permit 10.0.1.0/24 ! ! route-map bgp permit 10 match ip address prefix-list bgp ! ! ! ! ! control-plane ! ! line con 0 stopbits 1 line aux 0 stopbits 1 line vty 1 length 0 line vty 2 4 ! ! end
ROUTER ONE
version 16.10 service timestamps debug datetime msec service timestamps log datetime msec platform qfp utilization monitor load 80 no platform punt-keepalive disable-kernel-core platform console serial ! hostname CISCOHUB1 ! boot-start-marker boot-end-marker ! ! vrf definition GS rd 100:100 ! address-family ipv4 exit-address-family ! logging persistent size 1000000 filesize 8192 immediate ! aaa new-model ! ! aaa authentication login default local aaa authorization exec default local none ! ! ! ! ! aaa session-id common ! ! ! ! ! ! ! ip domain name **** ! ! ! login on-success log ! ! ! ! ! ! ! subscriber templating ! ! ! ! ! multilink bundle-name authenticated ! crypto pki trustpoint TP-self-signed-3000728434 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-3000728434 revocation-check none rsakeypair TP-self-signed-3000728434 ! ! crypto pki certificate chain TP-self-signed-3000728434 certificate self-signed 01 30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030 31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274 69666963 6174652D 33303030 37323834 3334301E 170D3139 30343239 30393136 34335A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649 4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30303037 32383433 34308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201 0A028201 0100A50A EF289B44 7BDD7E51 3E4CF96C DF0F0605 FE3A202C 68572DC5 E5F6EB0E 5B4A8844 1B3422A3 185FA349 0F082469 47ABE355 0284F9CF 5798B96C 3358DCF7 8AD1934B 8EDABB7A 8E12C5AF 74F1740F 1F15C661 73C596F3 7A540D76 F193B0D2 D97A088E 782FE6EA 950776CD 68DC0A93 2D5BEE3D D8C1FDAA E943B899 965E800C 64FB8D24 3B6D6A2B B192C590 C6565310 4EB2786B 517983DD 7B7A1432 FE9DD878 0E0F3768 8898994D 029ABDC9 EF129B59 97A36CB2 9FE323B0 A5AC51BF F6BCF1AE C5F1DD6A 38D0484B 0BDC1D5A DBC1BEFE 1EF6C390 C308DA07 BAE7DCF5 AB84C14B 28934FFB DC4446CB 7BD3BBE3 66C9F572 B69A0952 38C0982D 0BE3557B E88189EA 56950203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603 551D2304 18301680 141BD527 FE1550EA 8D8CE62F 3FA212ED C84FE91B 0B301D06 03551D0E 04160414 1BD527FE 1550EA8D 8CE62F3F A212EDC8 4FE91B0B 300D0609 2A864886 F70D0101 05050003 82010100 67698C64 DDDFE7A3 6CB0F5B5 EB0E7E53 9DED521B 21DEEE6A B14E9F43 2C4F6078 6BE9DBBA 18E0684C AF3F52EE C61D08DB 4DE961D0 B8C57511 FE0D2DD8 1B7F335C 5850911E 582EBD7C B31F92E5 2F82C54E 3CC1FACB 1EC95F3F 04268487 6E8201F7 59723959 1B5B419C CB118572 0DA939CA E2159910 890B799E A7E88756 64BFF3FE 640133B5 F8487EAC C746F1E5 C72FC639 F6BC2C97 56F64842 7C83F293 79727CC6 622EFC4C F5B5ABAA D7216DE7 0932E360 A0EEB384 B79D977E 39C3864A D379FE90 958A277E 5250322A 89934C3A 0EED9071 46A2D11D 19B28496 67610968 E4C2F1A3 FE59B448 1923D202 D0CC9139 2D06116A D54F9392 4E7D8C01 25036B3F 73EE6009 quit ! license udi pid CSR1000V sn **** no license smart enable diagnostic bootup level minimal ! ! ! username **** ! redundancy ! crypto ikev2 proposal azure-proposal encryption aes-cbc-256 aes-cbc-128 3des integrity sha1 group 2 ! crypto ikev2 policy azure-policy proposal azure-proposal ! crypto ikev2 keyring ONPREM peer 51.143.190.207 address 51.143.190.207 pre-shared-key **** ! ! ! crypto ikev2 profile ONPREM match address local interface GigabitEthernet1 match identity remote address 51.143.190.207 255.255.255.255 authentication remote pre-share authentication local pre-share keyring local ONPREM ! ! ! ! ! ! ! ! ! ! ! ! crypto ipsec transform-set azure-ipsec-proposal-set esp-aes 256 esp-sha-hmac mode tunnel ! crypto ipsec profile ONPREM set transform-set azure-ipsec-proposal-set set ikev2-profile ONPREM ! ! ! ! ! ! ! ! ! ! interface Loopback0 ip address 10.255.1.1 255.255.255.255 ! interface Tunnel1 description to ONPREM ip unnumbered Loopback0 ip tcp adjust-mss 1350 tunnel source GigabitEthernet1 tunnel mode ipsec ipv4 tunnel destination 51.143.190.207 tunnel protection ipsec profile ONPREM ! interface GigabitEthernet1 ip address dhcp negotiation auto ! interface GigabitEthernet2 ip address dhcp negotiation auto ! router bgp 65001 bgp log-neighbor-changes bgp bestpath as-path multipath-relax neighbor 10.255.3.1 remote-as 65000 neighbor 10.255.3.1 ebgp-multihop 3 neighbor 10.255.3.1 update-source Loopback0 ! address-family ipv4 network 10.74.9.128 mask 255.255.255.128 neighbor 10.255.3.1 activate neighbor 10.255.3.1 route-map bgp out maximum-paths 16 exit-address-family ! ip forward-protocol nd no ip http server ip http secure-server ip route 10.74.0.0 255.255.0.0 10.74.9.129 ip route 10.255.3.1 255.255.255.255 Tunnel1 ! ip ssh rsa keypair-name sshkeys ! ! ip prefix-list bgp seq 5 permit 10.74.9.128/25 ! ! route-map bgpprepend permit 10 match ip address prefix-list bgp set as-path prepend 65001 65001 65001 ! route-map bgp permit 10 match ip address prefix-list bgp ! ! ! ! ! control-plane ! ! line con 0 stopbits 1 line aux 0 stopbits 1 line vty 1 length 0 line vty 2 4 ! ! ! ! ! ! end
