IPSEC clear crypto session - a way of automating this?
phil_carter
I have a GRE tunnel running over IPSEC across the Internet, providing connectivity between a remote site and our central router. Connectivity is intermittently hanging causing loss of connectivity. There is a bit of NAT going on in the middle via a checkpoint firewall (for our central router only), and at one stage the firewall logs reported the remote router was trying to use non-standard ports for IPSEC connecitivity (not 500 and/or 4500) - which were all being dropped. However, this is not currently being seen and the problem remains.
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
lifetime 180
crypto isakmp key xxxxxx address x.x.x.x
crypto isakmp invalid-spi-recovery
crypto ipsec security-association idle-time 300
crypto ipsec transform-set xxxxxx_Transform esp-3des esp-md5-hmac
crypto ipsec profile VTI
set transform-set xxxxxx_Transform
interface Tunnel1
ip address 172.16.122.38 255.255.255.252
ip mtu 1400
load-interval 30
tunnel source Dialer1
tunnel destination x.x.x.x
tunnel mode ipsec ipv4
tunnel protection ipsec profile VTI
When connectivity is lost to the remote site, the central router still displays an ACTIVE in/outbound IPSEC tunnel (using 'show crypto ipsec sa'). However, clearing the crypto session at the central end forces the IPSEC to renogotiate and come back up (using the default ports 500 / 4500).
I added the "crypto ipsec security-association idle-time 300" line in the hope that after 5 mins of idle-ness this would happen automatically, but this doesn't work.
Is there a way of forcing a reset to IPSEC automatically given a loss of traffic/idle state??
Rgds
Phil
5 Replies 5
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Perhaps a re-occurring script could be run on the router that looks at the crypto stats, and depending on what it "sees", clear the SA.
Phil
Creating a script to issue the clear crypto commands as Joseph suggests would be the easy part. The challenge would be in creating something that would detect when connectivity to the remote was lost. Perhaps there is something in IP SLA that could do this and kick off a script if connectivity goes down.
Rick
Rick
wleeb1010
Setup sla and corresponding tracker that ping the remote <internal ip> of tunnel
  • ip sla 1
  •  icmp-echo 10.255.0.1
  •  threshold 1000
  •  timeout 4000
  •  frequency 5
  • ip sla schedule 1 life forever start-time now
  • track 1 ip sla 1 reachability
Setup EEM applet that resets the tunnel by issuing a "clear crypto session remote <public ip>" if the corresponding tracker returns a state of down
  • event manager applet track-1 authorization bypass
  • event track 1 state down
  • action 0001 cli command "enable"
  • action 0002 cli command "clear crypto session remote 4.3.2.1"
  • action 0003 syslog msg  "Tunnel0 has gone down and was reset"
Curious how the clear crypto remote command works.  For me the interface comes up and goes right back down.  the clear crypto works.
tlovely
a variant of the SLA would be to monitor the syslog mine looks like this.  Keep in mind if the interface is not going down you will have to track another syslog message.
event manager applet Crypto_Recovery
event syslog pattern "%LINEPROTO-5-UPDOWN: Line protocol on interface Tunnel0, changed state to down"
action 10 cli command "clear crypto session"
action 20 syslog priority informational msg "tunnel0 was reset by EMA"
