IPSEC encryption domains on IOS routers
trfinkenstadt
Hi, Group,
Is there a fundamental difference in using the following encryption domains in crypto map configurations:
ip access-list extended encdom-custA
 permit ip host 10.1.1.4 host 192.168.4.1
 permit ip host 10.1.1.5 host 192.168.4.1
and
ip access-list extended encdom-custA-alternate
 permit ip 10.1.1.4 0.0.0.1 host 192.168.4.1
Do both sides have to use summarized/wildcard masked values or do either work?
thanks in advance,
tim
Hitesh Vinzoda
Level 4
Level 4
Hi Tim,
The Crypto ACL doesnt have to be exact mirror; below are my findings
R4
crypto isakmp policy 1
 hash md5
 authentication pre-share
 group 2
 lifetime 28800
crypto isakmp key test123 address 155.1.45.5
crypto ipsec transform-set DES-MD5 esp-3des esp-md5-hmac
 mode tunnel
crypto map VPN 1 ipsec-isakmp
 set peer 155.1.45.5
 set security-association lifetime seconds 28800
 set transform-set DES-MD5
 match address 101
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
R5
 hash md5
 group 2
 lifetime 28800
crypto isakmp key test123 address 155.1.45.4
 mode tunnel
 set peer 155.1.45.4
 match address 101
access-list 101 permit ip host 192.168.2.1 host 192.168.1.1
Show outputs
R4
R4#show crypto ipsec sa
interface: Ethernet0/0.45
    Crypto map tag: VPN, local addr 155.1.45.4
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.1.1/255.255.255.255/0/0)
   remote ident (addr/mask/prot/port): (192.168.2.1/255.255.255.255/0/0)
   current_peer 155.1.45.5 port 500
     PERMIT, flags={}
    #pkts encaps: 9, #pkts encrypt: 9, #pkts digest: 9
    #pkts decaps: 9, #pkts decrypt: 9, #pkts verify: 9
R5
R5#show crypto ipsec sa
    Crypto map tag: VPN, local addr 155.1.45.5
   local  ident (addr/mask/prot/port): (192.168.2.1/255.255.255.255/0/0)
   remote ident (addr/mask/prot/port): (192.168.1.1/255.255.255.255/0/0)
   current_peer 155.1.45.4 port 500
     PERMIT, flags={origin_is_acl,}
So you can see from above output that ACL's weren't the same on both the sides but it matched a portion and IPsec SA was created and was able to pass the traffic.
Hope this helps
Hitesh
Pls rate useful posts
Hitesh Vinzoda
Level 4
Level 4
Hi Tim,
R4
 hash md5
 group 2
 lifetime 28800
 mode tunnel
 set peer 155.1.45.5
 match address 101
R5
 hash md5
 group 2
 lifetime 28800
 mode tunnel
 set peer 155.1.45.4
 match address 101
Show outputs
R4
     PERMIT, flags={}
R5
Hope this helps
Hitesh
Hitesh,
That does help.. I've typically always done mirrored encryption domains to avoid unintended consequences.
--tim
