IPsec tunnel issue (between Cisco & Fortigate)
Hey all,
Right now im trying to establish a site to site IPsec between a Cisco 2900 Router and a FortiGate 40F Firewall. The FortiGate GUI shows that the Tunnel is UP, but on the Cisco it's still not working.Topologie.png
Debug on Cisco:
000087: *Aug 17 17:04:36.311 MET: IKEv2-ERROR:Couldn't find matching SA: Detected an invalid IKE SPI
000088: *Aug 17 17:04:36.311 MET: IKEv2-PAK:(SESSION ID = 0,SA ID = 0):Next payload: ENCR, version: 2.0 Exchange type: INFORMATIONAL, flags: RESPONDER Message id: 0, length: 88
000089: *Aug 17 17:04:36.311 MET: IKEv2-ERROR:: A supplied parameter is incorrect
000090: *Aug 17 17:04:36.311 MET: IKEv2-ERROR:Couldn't find matching SA: Detected an invalid IKE SPI
000091: *Aug 17 17:04:36.311 MET: IKEv2-PAK:(SESSION ID = 0,SA ID = 0):Next payload: ENCR, version: 2.0 Exchange type: INFORMATIONAL, flags: RESPONDER Message id: 0, length: 88
000092: *Aug 17 17:04:36.311 MET: IKEv2-ERROR:: A supplied parameter is incorrect
000093: *Aug 17 17:04:36.315 MET: IKEv2-PAK:(SESSION ID = 1415,SA ID = 1):Next payload: ENCR, version: 2.0 Exchange type: IKE_AUTH, flags: RESPONDER MSG-RESPONSE Message id: 1, length: 248
Payload contents:
IDr Next payload: AUTH, reserved: 0x0, length: 13
Id type: FQDN, Reserved: 0x0 0x0
AUTH Next payload: SA, reserved: 0x0, length: 56
Auth method PSK, reserved: 0x0, reserved 0x0
SA Next payload: TSi, reserved: 0x0, length: 44
last proposal: 0x0, reserved: 0x0, length: 40
Proposal: 1, Protocol id: ESP, SPI size: 4, #trans: 3 last transform: 0x3, reserved: 0x0: length: 12
type: 1, reserved: 0x0, id: AES-CBC
last transform: 0x3, reserved: 0x0: length: 8
type: 3, reserved: 0x0, id: SHA384
last transform: 0x0, reserved: 0x0: length: 8
type: 5, reserved: 0x0, id: Don't use ESN
TSi Next payload: TSr, reserved: 0x0, length: 24
Num of TSs: 1, reserved 0x0, reserved 0x0
TS type: TS_IPV4_ADDR_RANGE, proto id: 0, length: 16
start port: 0, end port: 65535
start addr: 172.19.58.2, end addr: 172.19.58.2
TSr Next payload: NONE, reserved: 0x0, length: 24
start addr: 172.20.32.2, end addr: 172.20.32.2
Debug on FortiGate:
ike 0:IPSEC:7729: enc 2700000D02000000466F7274692100003802000000A1A3E9C1FB05665A8AB9748404008262F793B2510A84C615558286D7FFF1569F7889FA0CB2F1EAE0A2DA2009911FF2B92C00002C00000028010304036D41372C0300000C0100000C800E0100030000080300000D00000008050000002D00001801000000070000100000FFFFAC133A02AC133A020000001801000000070000100000FFFFAC142002AC1420020E0D0C0B0A0908070605040302010E
ike 0:IPSEC:7729: out 4D03AA75B993DBA72D3755CF2BF798B02E20232000000001000000F8240000DC174306D41DC510A0F9A9EDC94D411DEE2E0AA47BA8F857C666AA0CCCC28A1B058A94311E85A9A4477409C8F0C364D22E27F1B1D5634AEF36F061C2DCB72207E5D1DF7B73620D806CCD4E3ADBE604553E10BEC0F76A6B29735607BF2C82678C5222F8BE4BEC53A0758B3327942E3D7A6E0B823D28CB8A3C5C91677B0A02C59473A58552631BEF6B2AEB9CB8E1EC30C72CF0D627C4427580FC1B770C85105D57BAD4636613CA094ABB5378AE960D7BE00C3DE5E23EC354C0789C0BC111D2BAE6C67328CE6E06B08A4B38F8B0CF2F4FBEC32F5BADD2E0F21768
ike 0:IPSEC:7729: sent IKE msg (AUTH_RESPONSE): 20.113.40.21:500->20.113.40.20:500, len=248, id=4d03aa75b993dba7/2d3755cf2bf798b0:00000001
ike 0:IPSEC:7728: out F27D1FE3C91885D98A05085C5F95F1912E20250000000000000000582A00003CDEBE755BEE14AA3E05D75C1BACE79CCEB60CD47A75238020AFFF57DFBFFF3563A63F973935DED013AEE8B71516FCEF3A2A0010CFABE38B40
ike 0:IPSEC:7728: sent IKE msg (RETRANSMIT_INFORMATIONAL): 20.113.40.21:500->20.113.40.20:500, len=88, id=f27d1fe3c91885d9/8a05085c5f95f191
ike shrank heap by 159744 bytes
ike 0: comes 20.113.40.20:500->20.113.40.21:500,ifindex=8....
ike 0: IKEv2 exchange=SA_INIT id=4b41e0a2391b4cb9/0000000000000000 len=398
ike 0: in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
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: responder received SA_INIT msg
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: VID unknown (19): CISCO-DELETE-REASON
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: VID unknown (15): CISCOVPN-REV-02
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: VID unknown (19): CISCO-DYNAMIC-ROUTE
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: VID unknown (17): FLEXVPN-SUPPORTED
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: incoming proposal:
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: proposal id = 1:
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: protocol = IKEv2:
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: encapsulation = IKEv2/none
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: type=ENCR, val=AES_CBC (key_len = 256)
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: type=INTEGR, val=AUTH_HMAC_SHA2_384_192
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: type=PRF, val=PRF_HMAC_SHA2_384
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: type=DH_GROUP, val=MODP1536.
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: matched proposal id 1
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: lifetime=3600
ike 0:4b41e0a2391b4cb9/0000000000000000:7730: SA proposal chosen, matched gateway IPSEC
ike 0: found IPSEC 20.113.40.21 8 -> 20.113.40.20:500
ike 0:IPSEC:7730: responder preparing SA_INIT msg
ike 0:IPSEC:7730: out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
ike 0:IPSEC:7730: sent IKE msg (SA_INIT_RESPONSE): 20.113.40.21:500->20.113.40.20:500, len=312, id=4b41e0a2391b4cb9/87099916dc3ead42
ike 0:IPSEC:7730: IKE SA 4b41e0a2391b4cb9/87099916dc3ead42 SK_ei 32:46596C02B2EF32A2018CB458A971C77EA1FC656B58023EA4795D85BD37B5681E
ike 0:IPSEC:7730: IKE SA 4b41e0a2391b4cb9/87099916dc3ead42 SK_er 32:F3915C9CE92F8D6A9816CAAE3BC70C09AA619E7B40614E4B0E2247EF1C5C1E75
ike 0:IPSEC:7730: IKE SA 4b41e0a2391b4cb9/87099916dc3ead42 SK_ai 48:3018E934FD70B307ADF82D83D28FE2C45DB13C1A6AA7B3AE20028EE8B3141CF6EC80007BD7055117B82D140175A348B0
ike 0:IPSEC:7730: IKE SA 4b41e0a2391b4cb9/87099916dc3ead42 SK_ar 48:D63CE52C9CCD093485BE16DFFE8855C35C17C890EE1B2EFC4403A637D8806E9C3DD8E248FEFC625E9D4FB4FDC68C5B8C
ike 0: IKEv2 exchange=AUTH id=4b41e0a2391b4cb9/87099916dc3ead42:00000001 len=296
ike 0: in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
ike 0:IPSEC:7730: dec 4B41E0A2391B4CB987099916DC3EAD422E20230800000001000000F82B000004230000144A41E1A22A2CBFFE3B262D535015BC622700000C01000000147128142100003802000000B983ACAAC629AD5EE7A0F8BDE8A19774E0492AB18C48649C47D51515F6A7C05AB8C151944545728477AC237E444F4EE02C00002C00000028010304032648F4F10300000C0100000C800E0100030000080300000D00000008050000002D00001801000000070000100000FFFFAC133A00AC133AFF2900001801000000070000100000FFFFAC142000AC1420FF29000008000040002900000C0000400100000005290000080000400A000000080000400B
ike 0:IPSEC:7730: responder received AUTH msg
ike 0:IPSEC:7730: processing notify type INITIAL_CONTACT
ike 0:IPSEC:7730: processing notify type SET_WINDOW_SIZE
ike 0:IPSEC:7730: processing notify type ESP_TFC_PADDING_NOT_SUPPORTED
ike 0:IPSEC:7730: processing notify type NON_FIRST_FRAGMENTS_ALSO
ike 0:IPSEC:7730: peer identifier IPV4_ADDR 20.113.40.20
ike 0:IPSEC:7730: auth verify done
ike 0:IPSEC:7730: responder AUTH continuation
ike 0:IPSEC:7730: authentication succeeded
ike 0:IPSEC:7730: responder creating new child
ike 0:IPSEC:7730:7761: peer proposal:
ike 0:IPSEC:7730:7761: TSi_0 0:172.19.58.0-172.19.58.255:0
ike 0:IPSEC:7730:7761: TSr_0 0:172.20.32.0-172.20.32.255:0
ike 0:IPSEC:7730:PHASE2:7761: comparing selectors
ike 0:IPSEC:7730:PHASE2:7761: matched by rfc-rule-4
ike 0:IPSEC:7730:PHASE2:7761: phase2 matched by intersection
ike 0:IPSEC:7730:PHASE2:7761: accepted proposal:
ike 0:IPSEC:7730:PHASE2:7761: TSi_0 0:172.19.58.2-172.19.58.2:0
ike 0:IPSEC:7730:PHASE2:7761: TSr_0 0:172.20.32.2-172.20.32.2:0
ike 0:IPSEC:7730:PHASE2:7761: autokey
ike 0:IPSEC:7730:PHASE2:7761: incoming child SA proposal:
ike 0:IPSEC:7730:PHASE2:7761: proposal id = 1:
ike 0:IPSEC:7730:PHASE2:7761: protocol = ESP:
ike 0:IPSEC:7730:PHASE2:7761: encapsulation = TUNNEL
ike 0:IPSEC:7730:PHASE2:7761: type=ENCR, val=AES_CBC (key_len = 256)
ike 0:IPSEC:7730:PHASE2:7761: type=INTEGR, val=SHA384
ike 0:IPSEC:7730:PHASE2:7761: type=ESN, val=NO
ike 0:IPSEC:7730:PHASE2:7761: PFS is disabled
ike 0:IPSEC:7730:PHASE2:7761: matched proposal id 1
ike 0:IPSEC:7730:PHASE2:7761: lifetime=3600
ike 0:IPSEC:7730: responder preparing AUTH msg
ike 0:IPSEC:7730: established IKE SA 4b41e0a2391b4cb9/87099916dc3ead42
ike 0:IPSEC:7730: processing INITIAL-CONTACT
ike 0:IPSEC: flushing
ike 0:IPSEC: deleting IPsec SA with SPI f256164b
ike 0:IPSEC:PHASE2: deleted IPsec SA with SPI f256164b, SA count: 0
ike 0:IPSEC: sending SNMP tunnel DOWN trap for PHASE2
ike 0:IPSEC:7729:PHASE2:7759: sending delete for IPsec SA SPI 6d41372c
ike 0:IPSEC:7729:7762: send informational
ike 0:IPSEC:7729: enc 0000000C030400016D41372C03020103
ike 0:IPSEC:7729: out 4D03AA75B993DBA72D3755CF2BF798B02E20250000000000000000582A00003C8431BC904EE0B39CB86B33B361B073372A1F48DE48C9F5CC64E457F2D31BE09E1A82C203447FECFEEFA6998EEE4B25655D6452CAC7EF946B
ike 0:IPSEC:7729: sent IKE msg (INFORMATIONAL): 20.113.40.21:500->20.113.40.20:500, len=88, id=4d03aa75b993dba7/2d3755cf2bf798b0
ike 0:IPSEC:PHASE2: sending SNMP tunnel DOWN trap
ike 0:IPSEC: deleting IPsec SA with SPI 133511a1
ike 0:IPSEC:7729:7763: send informational
ike 0:IPSEC:7729: enc 00000008010000000706050403020107
ike 0:IPSEC:7729: out 4D03AA75B993DBA72D3755CF2BF798B02E20250000000000000000582A00003CEF40F7B603616AD2E1573F35D59CD1E7262777831816763A37C4F8BAC9D2FC98547BA92C16C0AB9AAD460162A7A8F81A215A1675FB567B00
ike 0:IPSEC: schedule auto-negotiate
ike 0:IPSEC:7728:7764: send informational
ike 0:IPSEC:7728: enc 00000008010000000706050403020107
ike 0:IPSEC:7728: out F27D1FE3C91885D98A05085C5F95F1912E20250000000000000000582A00003CF42448826441A894C9C2770C75C25B046A898AD75F9835C16B5FF21E528FE7D7BE57E35E400F28FE1A83EA12AA6E48ABB6F838B5342AA374
ike 0:IPSEC:7728: sent IKE msg (INFORMATIONAL): 20.113.40.21:500->20.113.40.20:500, len=88, id=f27d1fe3c91885d9/8a05085c5f95f191
ike 0:IPSEC: flushed
ike 0:IPSEC:7730: processed INITIAL-CONTACT
ike 0:IPSEC:7730:PHASE2:7761: replay protection enabled
ike 0:IPSEC:7730:PHASE2:7761: set sa life soft seconds=3331.
ike 0:IPSEC:7730:PHASE2:7761: set sa life hard seconds=3600.
ike 0:IPSEC:7730:PHASE2:7761: IPsec SA selectors #src=1 #dst=1
ike 0:IPSEC:7730:PHASE2:7761: src 0 7 0:172.20.32.2-172.20.32.2:0
ike 0:IPSEC:7730:PHASE2:7761: dst 0 7 0:172.19.58.2-172.19.58.2:0
ike 0:IPSEC:7730:PHASE2:7761: add IPsec SA: SPIs=6d41372d/2648f4f1
ike 0:IPSEC:7730:PHASE2:7761: IPsec SA dec spi 6d41372d key 32:736CCBF9D6876A594EF14BC44E5946595ADF77F0655B879D5C8C3FBAE058BC94 auth 48:2D7AB0D922D6B18EA76FCB4A308B3EDF4AF871854AD7F6EBDD9842F5679A76723C738DFCDA31017847FD1CA0C858E01E
ike 0:IPSEC:7730:PHASE2:7761: IPsec SA enc spi 2648f4f1 key 32:3CABDB3478713846F4DADCB1197732547791E244C87A1ED129FF30045DA412F9 auth 48:F9AEE42BA3CDD0393ABCEC5E1D880A3E1B0A1E233DF43BC7EA1D83ED9750DCC360FF0E75E74681F88B8415D9E62371C6
ike 0:IPSEC:7730:PHASE2:7761: added IPsec SA: SPIs=6d41372d/2648f4f1
ike 0:IPSEC:7730:PHASE2:7761: sending SNMP tunnel UP trap
ike 0:IPSEC:7730: enc 2700000D02000000466F7274692100003802000000B8D1BB750C3279675975B8782E9A42CAA051D144FF7F9E585BD17294A9BFAC788B8F39545535627302FA06894488DF302C00002C00000028010304036D41372D0300000C0100000C800E0100030000080300000D00000008050000002D00001801000000070000100000FFFFAC133A02AC133A020000001801000000070000100000FFFFAC142002AC1420020E0D0C0B0A0908070605040302010E
ike 0:IPSEC:7730: out 4B41E0A2391B4CB987099916DC3EAD422E20232000000001000000F8240000DC087B8FA70D0B95FCDA07DCFC580AD0B95A988347E965A284169328278C8AAAF3178B2800CC62BC4E38034EDFA06A377A7BD84D9150BD77A6312CCDC5BADC025958C88D7109EDA008ECCD45BD30258DF59D3C5A099AF40177C721209EA29E5486339F35DB4702AEB9793684176019006E5CABCA62B9179AFC349DD19A0DE2A44DA90F322BE0E28B4B7D9E00CCEBE862BA9E672BF08966FA9FB5DC524E37D82D0A6052E9371678BC2EB10213A36B986FAA9A8A8797999559A02B80B8DE79989F63F21C3B11DF049076A0052C67249B17A30556BBC613A93808
ike 0:IPSEC:7730: sent IKE msg (AUTH_RESPONSE): 20.113.40.21:500->20.113.40.20:500, len=248, id=4b41e0a2391b4cb9/87099916dc3ead42:00000001
Cisco Config:
Current configuration : 5883 bytes
redundancy
crypto ikev2 proposal FortiProposal
encryption aes-cbc-256
integrity sha384
group 5
crypto ikev2 policy FortiPolicy
match address local 20.113.40.20
crypto ikev2 keyring FortiKeyring
peer Forti
address 20.113.40.21 255.0.0.0
pre-shared-key pskey
crypto ikev2 profile FortiProfile
match identity remote address 20.113.40.21 255.255.255.255
identity local address 20.113.40.20
authentication remote pre-share
authentication local pre-share
keyring local FortiKeyring
no crypto ikev2 http-url cert
crypto logging session
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 30 periodic
crypto ipsec security-association idle-time 60
crypto ipsec transform-set FortiTransform esp-aes 256 esp-sha384-hmac
mode tunnel
no crypto ipsec nat-transparency udp-encapsulation
crypto map FortiMap 10 ipsec-isakmp
set peer 20.113.40.21
set transform-set FortiTransform
set pfs group5
set ikev2-profile FortiProfile
match address FortiAccess
interface Loopback0
no ip address
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 20.113.40.20 255.0.0.0
duplex auto
speed auto
no cdp enable
crypto map FortiMap
interface GigabitEthernet0/1
ip address 172.19.58.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 172.20.32.0 255.255.255.0 GigabitEthernet0/0 20.113.40.21
ip access-list extended FortiAccess
permit ip 172.19.58.0 0.0.0.255 172.20.32.0 0.0.0.255
permit ip 20.0.0.0 0.255.255.255 172.20.32.0 0.0.0.255
end
FortiGate Config:
config vpn ipsec phase1-interface
edit "IPSEC"
set interface "lan3"
set ike-version 2
set local-gw 20.113.40.21
set keylife 3600
set peertype any
set net-device disable
set proposal aes256-sha384
set localid "Forti"
set dhgrp 5
set nattraversal disable
set remote-gw 20.113.40.20
set psksecret ENC goAzR4xNf31WsVq6AP0WfRzZobw8jpJh4PTTInPYicYLgQx1qWB7AAAdl+hPWT0if/kTNJBGPgnJhb13fj2PSzhqS56m7d5DaqT2sZyiXlH1nVprjpDQ/NX3AsRSShh2V7CvKnENvVl3CvPo2z2NYg0GOiU/CjcLZIFD9MMM06hGRPd7f9c6aEBi5h5YrCrRYv4/vA==
next
end
config vpn ipsec phase2-interface
edit "PHASE2"
set phase1name "IPSEC"
set dhgrp 5
set keepalive enable
set keylifeseconds 3600
set src-subnet 172.20.32.2 255.255.255.255
set dst-subnet 172.19.58.2 255.255.255.255
next
end
I would be very thankful if you informed about any possible mistakes and its solution
Martin
15 Replies 15
Fantastic ! Thanks for posting these...
