IPSEC tunnel issue between ISR4331 and Palo alto
vithoba
we have IPSEC tunnel between cisco ISR router ISR4331/K9 and Palo alto. Getting below messages. The Tunnel interface is up but users unable to browse internet/intranet. When we manually run clear crypto sa peer 161.202.161.11 after that it works and users able to use internet and other applications. This is happening repetitively now.
000702: Sep 22 02:17:49.847 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
000721: Sep 22 03:44:04.633 UTC: %IOSXE-4-PLATFORM: SIP1: cpp_cp: QFP:0.0 Thread:001 TS:00000093734079972594 %CERM_DP-4-DP_TX_BW_LIMIT: Maximum Tx Bandwidth limit of 85000 Kbps reached for Crypto functionality with securityk9 technology package license.
000791: Sep 22 05:03:45.818 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
000871: Sep 22 05:04:45.866 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
000950: Sep 22 05:05:45.855 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
001030: Sep 22 05:06:45.855 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
001110: Sep 22 05:07:45.853 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
001191: Sep 22 05:08:45.873 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
crypto keyring SINGARING
pre-shared-key address 161.202.161.11 key McY2k16!
crypto isakmp policy 16
encr aes
authentication pre-share
group 2
crypto isakmp key McY2k16! address 161.202.161.11
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 30 5
crypto isakmp profile ISAKMP-PRO
keyring SINGARING
match identity address 161.202.161.11 255.255.255.255
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set TSET esp-aes esp-sha-hmac
mode tunnel
crypto ipsec profile NewPaloProfile
set transform-set TSET
set isakmp-profile ISAKMP-PRO
14 Replies 14
Hello
Please review this here
Kind Regards
Paul
vithoba
Thanks Paul for the reply. What about the other error?
Hello
I evsiisage you need to procur a HSEC-K9 license for the rtr
Kind Regards
Paul
vithoba
The phase 1 tunnel is not established, below is the current status.
#sh crypto isakmp sa detail
Codes: C - IKE configuration mode, D - Dead Peer Detection
K - Keepalives, N - NAT-traversal
T - cTCP encapsulation, X - IKE Extended Authentication
psk - Preshared key, rsig - RSA signature
renc - RSA encryption
IPv4 Crypto ISAKMP SA
C-id Local Remote I-VRF Status Encr Hash Auth DH Lifetime Cap.
1157 203.121.70.198 161.202.161.11 ACTIVE aes sha psk 2 0 D
Engine-id:Conn-id = ???
(deleted)
008767: Sep 23 08:36:18.647 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
008848: Sep 23 08:37:18.635 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
008930: Sep 23 08:38:18.625 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
009012: Sep 23 08:39:18.625 UTC: %CRYPTO-6-ISAKMP_MANUAL_DELETE: IKE SA manually deleted. Do 'clear crypto sa peer 161.202.161.11' to manually clear IPSec SA's covered by this IKE SA.
AP-MAL-KL-VPN#sh clo
08:39:52.222 UTC Fri Sep 23 2022
keyring SINGARING <<- you use this keyring where is the config of it??
johnlloyd_13
Level 9
Level 9
hi,
can you post a 'show run' and mask/remove sensitive info (public IP, key string).
make sure you've configured this in your GRE tunnel:
interface Tunnelx
 ip mtu 1400
 ip tcp adjust-mss 1360
Below is the IPSEC tunnel configuration.
encryption aes
hash sha
group 2
crypto isakmp key yyyyyyyy address x.x.x.x
keyring SINGARING
match identity address x.x.x.x 255.255.255.255
mode tunnel
interface Tunnel6
no ip address
interface Tunnel16
description SINGAPURE-IBM-PA-[TUNNEL13]
ip address 10.2.7.42 255.255.255.252
keepalive 2800 3
tunnel source GigabitEthernet0/0/1
tunnel mode ipsec ipv4
tunnel destination x.x.x.x
tunnel protection ipsec profile NewPaloProfile
but you have only key in global mode not under keyring ??
encryption aes
hash sha
group 2
keyring SINGARING
mode tunnel
interface Tunnel6
no ip address
interface Tunnel16
keepalive 2800 3
crypto keyring keyring1 <<<
  pre-shared-key address 192.168.0.2 key cisco <<<
crypto isakmp profile profile1
   keyring keyring1
   match identity address 192.168.0.102 255.255.255.255
 this what I not see in config
sorry i missed it.
pre-shared-key address x.x.x.x key yyyyyyyyy
pre-shared-key address 0.0.0.0 0.0.0.0 key yyyyyyyyy
 show crypto ipsec sa
debug crypto isakmp
can you share the output
Note:- disable debug after finish troublshooting
the problem does not necessarily have to be the Cisco, it could also be on the Palo Alto side. Can you post the XML config from the PA ?
Thanks all for your support. Issue resolved after upgrading router IOS to latest available.
