Ipsec VPN between Cisco 800 series and Fortinet
Tazio4436
I am trying to do an ipsec VPN from a Fortinet Firewall to a Cisco 800 series router.
Please see the config on Fortinet side. Also we are allowing any traffic to come in on Fortinet for testing purposes and it is set in such a way that it will only allow connection when there is a request from the other device and in this case it is Cisco 800.
The reason why it has been done like that is to allow users to have the Cisco 800 and travel with that anywhere and he ip address will keep on changing.
Fortigate_100F # show vpn ipsec phase1-interface
config vpn ipsec phase1-interface
edit "TEST"
set type dynamic
set interface "wan1"
set keylife 28800
set peertype any
set net-device disable
set proposal des-md5
set dpd on-idle
set dhgrp 2
set psksecret ENC XXXXXXXXXXXX
set dpd-retryinterval 60
Fortigate_100F # show vpn ipsec phase2-interface
config vpn ipsec phase2-interface
edit "TEST"
set phase1name "TEST"
set pfs disable
set keepalive enable
set src-addr-type name
set dst-addr-type name
set keylifeseconds 86400
set src-name "all"
set dst-name "all"
next
end
On cisco 800 side we have tried to follow the steps from Cisco documents but we were not able to make it work.
The cisco 800 will be connected at home behind the ISP modem.So it will get a DHCP ip address I presume.
On int f4 (WAN interface) I have ip add DHCP configured.
All the other interface seem to be layer 2 and cannot configure ip address.
Please see attached config file for cisco 800.
Any help will be much appreciated.
Tazio
11 Replies 11
your Cisco router has no 'ip nat outside' on the FastEthernet4 interface but nothing else with regard to NAT configured ?
You might want to configure a VTI tunnel, rather than the 'legacy' crypto map.
I agree with @Georg Pauwen that the lack of configuration of address translation may be an issue. But there are more important issues that you need to address. The most important is that you indicate that the Fortinet expects the remote subnet to be 192.168.70.0. But there is nothing configured on the Cisco about that network. You should configure an IP address for vlan 1 to be in that network.
I also note that you do not have any routing statements (no static routes and no dynamic routing). I am not clear whether the Cisco will learn and use a default route from its DHCP negotiation with the ISP. In testing you should verify whether the Cisco has a default route in its routing table. If not something like this should be helpful
ip route 0.0.0.0 0.0.0.0 dhcp
Once you have configured ip addressing for vlan 1 and have verified the default route let us know if the vpn works any better. If it still does not work I would suggest as a next step in the troubleshooting would be to enable debug for isakmp negotiation. Lets see if the router is attempting to negotiate phase 1.
Rick
Ip nat outside added on int f4
And dhcp pool created as follows
ip dhcp excluded-address 192.168.70.1 192.168.70.10
ip dhcp pool INTERNAL
network 192.168.70.0 255.255.255.0
default-router 192.168.70.1
dns-server 8.8.8.8 4.2.2.1
My laptop is connected to port 3 on Cisco 800.
I can ping 8.8.8.8 from Cisco 800 but cannot ping from my laptop
Laptop got an Ip address from Cisco 800 DHCP
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 192.168.70.11
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.70.1
Sh ip route from Cisco 800
Router#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 192.168.70.1 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected
is directly connected, FastEthernet4
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/24 is directly connected, FastEthernet4
L 192.168.0.23/32 is directly connected, FastEthernet4
192.168.70.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.70.0/24 is directly connected, Vlan1
L 192.168.70.2/32 is directly connected, Vlan1
added the following ip route statements by by one to see if there is any change but nothing helped.
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip route 0.0.0.0 0.0.0.0 192.168.70.1
all debug outputs are empty
Router#debug crypto ipsec
Crypto IPSEC debugging is on
Router#debug crypto isakmp
Crypto ISAKMP debugging is on
Vlan 1 has an ip address
Now i going to try new configuration on another Cisco 800 for VTI tunnel and keep this configuration just in case you want me to to try something else.
Please see attached sh run
Thanks for help
Tazio
the only default route you need is this:
ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
Thanks for your quick reply.
Removed all default route and added only ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
I think ISAKMP phase 1 is not even coming up.
Router#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
This is how phase one is configured on Cisco 800
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
lifetime 28800
crypto isakmp key XXXXXXX address (WAN IP FOR FORTINET)
Please see attached file for options for phase 1 on Fortinet.
Tazio
does your crypto policy have:
encr 3des
--> hash md5
group 2
lifetime 28800
I have changed the config as follows but still nothing
encr 3des
hash md5<=============added this. It was missing
group 2
lifetime 28800
crypto isakmp key XXXXXXXX address (FORTINET WAN IP ADDRESS)
I have checked the key again to make sure there is no typo
Phase 1 still not coming up.
Tazio
from the Cisco, post the output of:
debug crypto isakmp
debug crypto ipsec
The debug output is not giving anything
debug all shows lots of information but not the 2 command you asked for.
Tazio
what happens if you send a ping from a local host to a host on the other side (that is, a ping within the IPSec domain) ?
Ping does not work if I try to ping a host on either side but I ping 8.8.8.8 or google.com.
I am reading some more documents for Cisco VPN and tried a different VPN which is dmvpn and with this one phase one is successful but cannot get phase 2 up.
I am not sure hoe dmvpn works but if this is also an option I can post the show run.
Tazio
