Ipsec Vpn in PAT configuration
prince.p
Hi All
I have configured IPsec VPN via PAT configuration in a packet tracer. In this, I could able to ping from R1 to R3 router IP address vice versa
But I can't able to ping from R1 LAN pc to R3 Lan Pc vice versa.
My Network  Router 1---- Router 2---- Router 3
Below is my configuration detail of Router1
Router1#sh run
Building configuration...
Current configuration : 1327 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip dhcp excluded-address 10.1.0.1 10.1.0.20
ip dhcp pool network
network 10.1.0.0 255.255.255.0
default-router 10.1.0.1
ip cef
no ipv6 cef
crypto isakmp policy 5
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco@123 address 40.165.10.1
crypto ipsec transform-set r1-r3 esp-aes 128 esp-md5-hmac
crypto map ipsec-map 10 ipsec-isakmp
set peer 40.165.10.1
set transform-set r1-r3
match address vpn-traffic
spanning-tree mode pvst
interface FastEthernet0/0
ip address 20.165.10.1 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip nat inside source list 1 interface FastEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 20.165.10.2
ip flow-export version 9
access-list 1 permit 10.1.0.0 0.0.0.255
ip access-list extended vpn-traffic
permit ip 10.1.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 10.1.0.0 0.0.0.255 any
line con 0
line aux 0
line vty 0 4
login
end
 Below is my Router 2 configuration
Router2#sh run
Current configuration : 583 bytes
version 12.4
hostname Router
ip cef
no ipv6 cef
ip address 20.165.10.2 255.255.255.252
duplex auto
speed auto
ip address 40.165.10.2 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Below is my Router 3 configuration
Router3#sh run
Current configuration : 1347 bytes
version 12.4
hostname Router
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp pool Router
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip cef
no ipv6 cef
encr 3des
group 2
crypto isakmp key cisco@123 address 20.165.10.1
set peer 20.165.10.1
ip address 40.165.10.1 255.255.255.252
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 40.165.10.2
access-list 1 permit 192.168.1.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 10.1.0.0 0.0.0.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
line con 0
line aux 0
line vty 0 4
login
end
can anyone help me how to configure IPsec VPN Via PAT configuration
2 Accepted Solutions
The first acl is used for NAT and you are saying do not NAT the 10.1.0.x IPs if the destination IPs are 192.168.1.x.
The second acl is used to tell the router which traffic to send down the VPN tunnel.
If you did not tell the router not to NAT those 10.1.0.x IPs in the first acl then the traffic would not match the second acl and would not be sent through the tunnel.
Jon
the access list on R3 is wrong. You have:
access-list 100 deny ip 192.168.0.0 0.0.0.255 10.1.0.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
It needs to be:
access-list 100 deny ip 192.168.1.0 0.0.0.255 10.1.0.0 0.0.0.255
11 Replies 11
typically, you need to deny the traffic that is going through the VPN from being NATted. Make the changes marked in bold to your Router1 and Router3 configurations:
Router1#
version 12.4
hostname Router
ip cef
no ipv6 cef
encr 3des
group 2
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip nat inside source list 100 interface FastEthernet0/0 overload
ip classless
access-list 100 deny 10.1.0.0 0.0.0.255 192.168.1.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
Router3#
version 12.4
hostname Router
ip dhcp pool Router
ip cef
no ipv6 cef
encr 3des
group 2
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
access-list 100 deny 192.168.1.0 0.0.0.255 10.1.0.0 0.0.0.255
access-list 100 permit 192.168.1.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
Hi Georg,
Thanks for your solution.i need to know why we need to deny traffic from R1 to R3.
In my configuration, I already permit traffic from R1 lan to R3 lan ie
# permit ip 10.1.0.0 0.0.0.255 192.168.1.0 0.0.0.255.
can you explain the reason why we need to deny traffic from R1 to R3 from being Nated
does it work now ?
Traffic within the VPN encryption domain must be excluded from NAT, because the VPN does not recognize the NAT address (that is the IP address of the NAT outside interface) and will drop it.
Hi georg,
I need to know we deny and permit same IP address for the access-list
In first acl we deny traffic 10.1.0.0 0.0.0.255 192.168.0.1 0.0.0.255 and in second acl we permit same IP address. This makes me confuse . Can you please explain this.
Jon
thanks, Jon now my doubt is cleared
in addition to what Jon says, the access lists also need to mirror each other on each side of the VPN...
Thanks George. now my doubt is cleared
Hi George,
As you said i modified the command, but still I can't able to ping from Router 1 Lan to Router 3 Lan
Below is the command
Router 1
Router#sh run
Current configuration : 1354 bytes
version 12.4
hostname Router
ip cef
no ipv6 cef
encr 3des
group 2
crypto ipsec transform-set prince esp-aes 128 esp-md5-hmac
set transform-set prince
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
access-list 100 deny ip 10.1.0.0 0.0.0.255 192.168.0.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
Router 3
Router3#sh run
Current configuration : 1372 bytes
version 12.4
hostname Router3
ip dhcp pool Router
ip cef
no ipv6 cef
encr 3des
group 2
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
It needs to be:
Thanks, George
Now I can able to Ping from R1 LAN to R3 LAN
