IPSEC VPN Tunnel and VPN Client configuration on same router
Shahzad Ayub
I have a remote site which is connected to Head-office through IPSEC VPN Tunnel, now i want to configure our Head-office router for VPN-client configuration as well so that users will be connected using VPN-client to Head-office and they can access the resources at remote branch using already configured IPSEC VPN tunnel. I am posting specific configuration from Head office router and need expert advice that which specific configuration i required to achieve this.
interface Loopback0
 ip address 217.18.168.169 255.255.255.248
interface GigabitEthernet0/0
 description connected to ISP
 bandwidth 9000
 ip address 172.29.156.54 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 load-interval 30
 duplex auto
 speed auto
 crypto map CRYPTOMAP
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key cisco****** address 193.232.126.35
crypto ipsec transform-set REM_VPN esp-3des esp-md5-hmac
 mode tunnel
crypto map CRYPTOMAP local-address Loopback0
crypto map CRYPTOMAP 1 ipsec-isakmp
 set peer 193.232.126.35
 set transform-set REM_VPN
 match address SITE-TO-SITE
 reverse-route static
ip nat inside source list NAT interface Loopback0 overload
ip access-list extended SITE-TO-SITE
 permit ip 10.40.1.0 0.0.0.255 10.80.1.0 0.0.0.255
ip access-list extended NAT
 deny   ip 10.40.1.0 0.0.0.255 10.80.1.0 0.0.0.255
 permit ip 10.40.1.0 0.0.0.255 any
Shahzad
Francesco Molino
For doing Client VPN on the same router on which you're doing site-to-site VPN, I will not put right here all commands but redirect you on a link from Cisco explaining how to implement:
http://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/20982-ipsecrouter-vpn.html
However if you have issues, I would be able to help troubleshooting.
PS: Please don't forget to rate and mark as correct answer if this solved your issue.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Thanks for your reply.
I wrote some steps after looking at the document you referred, please review it and advise.
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
username cisco password 0 cisco
crypto isakmp client configuration group CLIENT-VPN
key cisco123
dns 10.100.9.5
domain local.*****.com
pool ippool
crypto dynamic-map dynmap 10
 reverse-route
crypto map CRYPTOMAP client authentication list userauthen
crypto map CRYPTOMAP isakmp authorization list groupauthor
crypto map CRYPTOMAP client configuration address initiate
crypto map CRYPTOMAP client configuration address respond
crypto map CRYPTOMAP 10 ipsec-isakmp dynamic dynmap
ip local pool ippool 10.100.20.100 10.100.20.254
Shahzad
It looks like ok.
PS: Please don't rate and mark as correct answer if this solved your issue
Francesco
