05-06-2021 08:04 AM
Dear all,
I'have a problem with my router. Some routes are stucked in BGP, my neighbor do not announce but my router always announce the network.
Also, i'have some errors in log and I want to know how to :
Percentage utilization of IPv4 native host routes : 2.63 Percentage utilization of IPv6 native host routes : 2.19 Percentage utilization of IPv6 ND/local routes : 2.19 Percentage utilization of IPv6 host /128 learnt routes : 0.00 Percentage utilization of IPv4 trie routes : 82.15 Percentage utilization of IPv6 trie routes : 21.60 Percentage utilization of IPv4 TCAM routes : 99.82 Percentage utilization of IPv6 TCAM routes : 94.92 Percentage utilization of nexthop entries : 3.74
How to adjust "Percentage utilization of IPv4 TCAM routes " ? Seem full, but If I check system ressources, it's okay :
PAR-N9K-1(config)# sh resource
Resource Min Max Used Unused Avail
vlan 16 4094 23 0 4071
vrf 2 4096 2 0 4094
port-channel 0 511 1 0 510
u4route-mem 768 768 127 641 641
u6route-mem 512 512 31 481 481
m4route-mem 58 58 1 57 57
m6route-mem 8 8 1 7 7
PAR-N9K-1(config)#
vdc PAR-N9K-1 id 1 limit-resource vlan minimum 16 maximum 4094 limit-resource vrf minimum 2 maximum 4096 limit-resource port-channel minimum 0 maximum 511 limit-resource u4route-mem minimum 768 maximum 768 limit-resource u6route-mem minimum 512 maximum 512 limit-resource m4route-mem minimum 58 maximum 58 limit-resource m6route-mem minimum 8 maximum 8
PAR-N9K-1(config)# show ver Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2019, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 05.39 NXOS: version 9.3(3) BIOS compile time: 08/30/2019 NXOS image file is: bootflash:///nxos.9.3.3.bin NXOS compile time: 12/22/2019 2:00:00 [12/22/2019 16:00:37] Hardware cisco Nexus9000 C93180YC-FX Chassis Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz with 65808192 kB of memory. Processor Board ID FDO22300362 Device name: PAR-N9K-1 bootflash: 115805356 kB Kernel uptime is 4 day(s), 1 hour(s), 6 minute(s), 20 second(s) Last reset at 594450 usecs after Sun May 2 15:57:19 2021 Reason: Reset Requested by CLI command reload System version: 9.3(3) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): PAR-N9K-1(config)#
Lot of errors in logging :
PAR-N9K-1(config)# sh logging last 10 2021 May 6 17:05:16 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2607:6100:100b::/48, flags:0x0, intf:0x10041c, Error: FIB TCAM FULL For IPV6 Routes(237) 2021 May 6 17:05:17 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2a06:e881:2606::/48, flags:0x0, intf:0x10041c, Error: Hw Trie full(201) 2021 May 6 17:05:18 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2607:6100:100b::/48, flags:0x0, intf:0x100040, Error: FIB TCAM FULL For IPV6 Routes(237) 2021 May 6 17:05:19 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2607:6100:100b::/48, flags:0x0, intf:0x10041c, Error: FIB TCAM FULL For IPV6 Routes(237) 2021 May 6 17:05:19 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2607:6100:100b::/48, flags:0x0, intf:0x100040, Error: FIB TCAM FULL For IPV6 Routes(237) 2021 May 6 17:05:20 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2607:6100:100b::/48, flags:0x0, intf:0x10041c, Error: FIB TCAM FULL For IPV6 Routes(237) 2021 May 6 17:05:21 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2607:6100:100b::/48, flags:0x0, intf:0x100040, Error: FIB TCAM FULL For IPV6 Routes(237) 2021 May 6 17:05:21 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2607:6100:100b::/48, flags:0x0, intf:0x10041c, Error: FIB TCAM FULL For IPV6 Routes(237) 2021 May 6 17:05:22 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2a0e:97c0:193::/48, flags:0x0, intf:0x100040, Error: FIB TCAM FULL For IPV6 Routes(237) 2021 May 6 17:05:22 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2402:53c0:2000::/36, flags:0x0, intf:0x100040, Error: Hw Trie full(201) PAR-N9K-1(config)#
Anyone have a magic command to fix all errors ?
Thanks !
Axel
05-06-2021 10:25 AM
Hi Axel,
"show resource" is for route memory utilization, not for TCAM utilization.
"show hardware internal forwarding table utilization" is for TCAM utilization and it looks like you have issues with the TCAM utilization.
Can you provide the output from the following command, to see what profile you are using:
sh runn | incl "system routing"
Ideally, you should be using the "system routing template-internet-peering".
05-06-2021 10:52 AM
Thanks for your reply. I already use system routing template :
PAR-N9K-1# sh runn | incl "system routing" system routing template-internet-peering PAR-N9K-1#
05-06-2021 12:42 PM
Hi Axel,
Two things to consider then.
1. Reduce the number of prefixes that you receive from your Service Provider. Are you receiving the full Internet routing table from them. If so, you might want to consider only receiving partial routes.
2. Replace the Nexus by something else. The Nexus9k was not originally designed as an Internet edge device and therefore comes with its limitations.
05-06-2021 02:03 PM
Thanks for your reply. I'have around 880 000 routes.
Can you know what is the error "Hw trie full" ? Also strange, because route memory (u4mem) is not full
Axel
05-06-2021 02:34 PM
Hi Axel,
HW trie is related to TCAM. As I mentioned before, u4mem is routing memory (urib). The issue you are having is with ufib.
05-07-2021 02:02 AM
Hello Harold,
Thanks against for your reply.
Small last question. For example, i'have a error for a prefix but If I check route, I see the path. Normal ? Not normal ?
PAR-N9K-1# sh logging last 10
2021 May 7 11:02:53 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 62.24.100.0/23, flags:0x0, intf:0x100138, Error: H
w Trie full(201)
2021 May 7 11:02:53 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 62.24.100.0/24, flags:0x0, intf:0x100138, Error: H
w Trie full(201)
2021 May 7 11:02:53 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 102.166.0.0/15, flags:0x0, intf:0x100138, Error: H
w Trie full(201)
2021 May 7 11:02:53 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 102.166.0.0/16, flags:0x0, intf:0x100138, Error: H
w Trie full(201)
2021 May 7 11:02:53 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 197.156.137.0/24, flags:0x0, intf:0x100138, Error:
Hw Trie full(201)
2021 May 7 11:02:53 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 102.135.169.0/24, flags:0x0, intf:0x100138, Error:
Hw Trie full(201)
2021 May 7 11:02:53 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 154.123.0.0/16, flags:0x0, intf:0x100138, Error: H
w Trie full(201)
2021 May 7 11:02:54 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2804:448c::/32, flags:0x0, intf:0x10041c, Error: H
w Trie full(201)
2021 May 7 11:02:54 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 2804:4ea8::/32, flags:0x0, intf:0x10041c, Error: H
w Trie full(201)
2021 May 7 11:02:54 PAR-N9K-1 %IPFIB-SLOT1-2-UFIB_ROUTE_CREATE: Unicast route create failed for INS unit 0, VRF: 1, 45.148.160.0/24, flags:0x0, intf:0x1000d1, Error:
FIB TCAM FULL For IP Routes(235)
PAR-N9K-1# show bgp ipv4 unicast 154.123.0.0
BGP routing table information for VRF default, address family IPv4 Unicast
BGP routing table entry for 154.123.0.0/18, version 5085384
Paths: (1 available, best #1)
Flags: (0x08001a) (high32 00000000) on xmit-list, is in urib, is best urib route, is in HW
Advertised path-id 1
Path type: external, path is valid, received and used, is best path, no labeled nexthop, in rib
AS-Path: 49434 174 3257 8966 12455 , path sourced external to AS
100.64.70.5 (metric 0) from 100.64.70.5 (193.178.0.1)
Origin incomplete, MED not set, localpref 100, weight 0
Community: 174:21100 174:22008 49434:101 49434:201 49434:301 49434:1000 49434:1001
Path-id 1 advertised to peers:
185.171.202.183 185.171.202.204 185.171.202.246
PAR-N9K-1#
05-07-2021 07:58 AM
Hi Axel,
It is normal to see the path in the BGP table. You will also see the route in the routing table (show ip route <prefix/prefixlen>). You will not see the route in the TCAM (show forwarding ipv4 route <prefix/prefixlen>).
05-07-2021 07:59 AM
Okay, thanks ! Small last question
There is an impact in production to not see route in TCAM ?
What impact if route is not present in TCAM ?
05-07-2021 08:46 AM
The Nexus 9k does not do software forwarding for transit traffic (page 121 of the below presentation). So if you don't have a summary route installed in the TCAM (including a default route), traffic to the specific destination for which the error was seen in the log will be dropped.
For more information about the Nexus9k architecture, you can refer to the following document:
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2016/pdf/BRKDCT-3101.pdf
05-07-2021 09:13 AM
Hello Harold,
it is interesting that the Nexus will drop packets for destinations not installed in the TCAM instead of using software based forwarding.
In the past for older platforms like Cat 6500 or Cisco 7600 (Sup720 based ) it was enough to change a linecard and to plug in the new linecard with the wrong daughter card DFC (non XL version ) and the whole system could experience a sudden increase in CPU usage of main CPU caused by process switching of traffic for destinations not stored on that linecard CEF table.
Best Regards
Giuseppe
05-07-2021 09:31 AM
Hi Giuseppe,
Long time no speak. Hope you are doing well.
Software forwarding was indeed supported as a fallback on those platforms, but created a lot of issues, as RP was able to support limited throughput and ended up causing high cpu in most cases. That was probably taken in consideration when designing the Nexus 9k family.
03-13-2025 03:05 AM
Hello Harold,
What is a difference between TCAM routes and trie routes that are presented in "show hardware internal forwarding table utilization" command.
Max IPv4 Trie route entries: 2000000
Max IPv6 Trie route entries: 628224
Max TCAM table entries : 24576
Max V4 Ucast TCAM table entries : 12288
Max V6 Ucast TCAM table entries : 4096
Percentage utilization of IPv4 trie routes : 40.30
Percentage utilization of IPv6 trie routes : 28.80
Percentage utilization of IPv4 TCAM routes : 99.88
Percentage utilization of IPv6 TCAM routes : 97.75
Percentage utilization of Nexthop entries : 0.61
1. Does both "TCAM routes" and "TRIE routes" refer to forwarding routes/prefixes and not for routing purposes?
2. if yes, when exactly "TCAM routes" region is utilized and when "trie routes" region is utilize? Why with regular BGP table and internet peering mode "TCAM routes" max-out whilst "trie routes" is half empty. Can it be due to some other configuration (eg. heavy utilization of SVI etc.)?
3. Are both of them (trie/TCAM) separated from other TCAM resoures (QoS,ACL,Netflow,...)?
Best regards,
Marcin
03-13-2025 10:16 AM
Hi @marcin.pietrkiewicz ,
I would suggest you open a new post to get assistance on this specific question, as the original post is quite old.
Harold
