IPv6 ACL Help.
kevin.hu
Level 3
Level 3
We have a new policy to block IPv6 routing header extension type 0, 1 and 3-255.  This is what I have came up:
ipv6 access-list inbound
deny ipv6 any any routing-type 0 log
deny ipv6 any any routing-type 1 log
However, I don't want to type every single ACL entry from 3 to 255.  From the CLI, I don't see a way to do 3 - 255.  Does anyone know?
So it would look like this:
deny ipv6 any any routing-type 3-255 log
Thanks.
Jerry Ye
You only want to permit routing-type 2? You can do the following
permit ipv6 any any routing-type 2 log
The ipv6 ACL will have an implicit deny ipv6 any any at the end.
jerry
Thanks Jerry.  But I still would like to know some kind of "range" command within IPv6 ACL.  Anyone else knows?
Hello Kevin,
current command reference does not provide a range option for routing-type a specific value is expected
see
http://www.cisco.com/en/US/docs/ios/ipv6/command/reference/ipv6_10.html#wp2268514
also because only first values have been defined for real use:
integer in the range from 0 to  255 representing an IPv6 routing header type. Possible routing header  types and their corresponding routing-number value are as follows:
0—Standard IPv6 routing header
2—Mobile IPv6 routing header
By the way, Jerry's solution should work well and shows how to deal with this limitation
if you want to add a third line to use log option you could use an explicit deny without any routing-type option.
Permitted routing type values are matched by previous lines
Edit:
in a previous line you can permit routing-type 2 ( I see is the only one you are interested to permit)
a second line can deny all the rest with log option
Hope to help
Giuseppe
