IPv6 BGP TTL-Security Problem
Kian Herng See
hi Experts,
Couldn't get the BGP IPv6 ttl-security to work, did i missed something?
The same configuration works for IPv4.
If i change the ttl-sercurity to large value e.g. 240, it will work, but that should not be
the case as TTL = 255 - (hop count).
Topology: R1(fa0/0)-----(fa0/0)R2
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T13, RELEASE SOFTWARE (fc3)
R1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
ipv6 address 2002:1:1:1::1/64
router bgp 100
no synchronization
bgp router-id 1.1.1.1
bgp log-neighbor-changes
neighbor 2002:1:1:1::2 remote-as 200
neighbor 2002:1:1:1::2 ttl-security hops 1
no auto-summary
address-family ipv6
neighbor 2002:1:1:1::2 activate
exit-address-family
R2
no ip address
duplex auto
speed auto
ipv6 address 2002:1:1:1::2/64
router bgp 200
no synchronization
bgp router-id 2.2.2.2
neighbor 2002:1:1:1::1 remote-as 100
neighbor 2002:1:1:1::1 ttl-security hops 1
no auto-summary
address-family ipv6
neighbor 2002:1:1:1::1 activate
exit-address-family
Router#debug ip bgp all
BGP debugging is on for all address families
Router#
Router#
Router#
Router#
*Mar  1 00:08:04.131: BGP: 2002:1:1:1::2 open active, local address 2002:1:1:1::1
*Mar  1 00:08:04.143: BGP: 2002:1:1:1::2 open failed: Connection refused by remote host
Hi See Kian Herng,
I tested in 12.4T, it is affected, and 15.0M has the fix. Can you read 'CSCsi53353', this one has similar bug description.
HTH,
Lei Tian
5 Replies 5
Lei Tian
Add 'ipv6 hop-limit 255' in the global configuration.
HTH,
Lei Tian
Tested the command, doesnt help. Found CSCsw45255, looks match the problem. Tested in 15.0(3)M code, is working.
Sorry for the wrong information.
HTH,
Lei Tian
hi Lei Tian,
Thanks for the prompt response.
The bug u mention is not available to public. Would it be possible for you
post the details?
This problem seem to affect wide range of platform & IOS.
I also tried older IOS 12.3 and it doesn't work also.
See Kian Herng
Hi See Kian Herng,
HTH,
Lei Tian
hi Lei Tian,
Yes, this bug i can view, thanks.
It seems to affect non T train also for 3725.
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(25c), RELEASE SOFTWARE (fc2)
There's no IOS 15.0 for this platform.  I will probably get 2 x 1841 and test it out.
Thanks alot, you been a geat help.
See Kian Herng
