IPv6 DHCP configuration
Steph1963
I am trying to configure a IPv6 DHCP server and I found the following thread discussing two different configurations:
https://learningnetwork.cisco.com/thread/10339
Configuration 1
ipv6 dhcp pool TEST
prefix-delegation 1111:2222::/32 1234ABCD
prefix-delegation pool TEST lifetime 1800 60
dns-server 1111:2222::13
domain-name PIPROUTING.NET
Configuration 2
ipv6 dhcp pool Test-Me2
  address prefix 2000:CC1E:0:1E1E::/64 lifetime infinite infinite
  link-address 2000:CC1E:0:1E1E::AA/64
Is there anybody who knows the difference between using
as opposed to
What it purpose of the link-address command? Will it be used by a DHCP client to determine it`s link-local address.
Note: Any link that would explain me the prefix-delegation would be greatly appreciated
Thanks for your help
Stéphane
Peter Paluch
Hi Stéphane,
Just a quick answer, certainly not covering all your questions but just as a starting point: try to read the following portion of the IOS Configuration Guide about IPv6:
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-dhcp_ps6441_TSD_Products_Configuration_Guide_Chapter.html
It may answer some of your questions.
Best regards,
Peter
Hi Peter,
The part that I do not understand with this delegation concept is the client-duid iaid
prefix-delegation ipv6-prefix/prefix-length client-duid [iaid iaid] [lifetime]
Router(config-dhcp)# prefix-delegation
2001:0DB8:1263::/48 0005000400F1A4D070D03
What is the client-duid [iaid], where can we find it on a host PC. Is it something we can configured on a PC or is it something that is present by default.
Stephane
Hello Stéphane,
The DUID is the DHCP Unique  Identifier. It is a value that uniquely identifies the DHCP client and  server. On a Cisco device, you can display it using the command
show ipv6 dhcp
It is described in the document I've referenced, specifically:
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-dhcp_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1055483
It is also used by DHCP clients such as PCs but because these clients do not use prefix delegation, you do not need to know the value for an ordinary PC.
Best regards,
Peter
