%IPV6_ND-4-DUPLICATE_OPTIMISTIC
alfredobosca
Hi folks
Last days, I am receiving again and again the next log message:
%IPV6_ND-4-DUPLICATE_OPTIMISTIC: Duplicate address FE80::5:73FF:FEA0:9 on GigabitEthernetx/x
FE80, indicates is a link-local IPv6 address so I guess it shouldn't be an issue but I would like to understand what's going on.
Could be affecting the router memory?
Best regards,
Mark Elsen
 - Could be a bug , check current software version on your device; if feasible , applicable and or depending on priority you may want to try more recent software release(s) and check if the problem persists.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
the only bug  could find was when an IPv6 address is configured on an SVI, which doesn't seem to be the case in your specific situation. There doesn't seem to be a workaround...
If you want to get rid of the message, either configure 'ipv6 nd dad attempts 0' on the interface that generates the log, or use a logging discriminator:
logging discriminator DAD severity drops 4 facility drops IPV6 mnemonics drops DUPLICATE_OPTIMISTIC
logging buffered discriminator DAD 100000
logging console discriminator DAD
logging monitor discriminator DAD
logging host ip_address_snmp_server discriminator DAD
possible bug
Kind Regards
Paul
Giuseppe Larosa
Hello @alfredobosca ,
I would say no I have just made a quick search on Cisco CCO bug search with keyword " %IPV6_ND-4-DUPLICATE_OPTIMISTIC"
no matching bugs found
being the ND messages sent out as multicast this might be the sign of a bridging loop somewhere in the network or a misbehaving MLD snooping switch that adds the source port to the oilist
searching over google auto-magically finds the following:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuf06043/?rfs=iqvred
Description
Symptom:
%IPV6_ND-4-DUPLICATE: Duplicate address
Conditions:
Configure ipv6 address on SVI interface
Workaround:
None
Customer Visible
Was the description about this Bug Helpful?
(4)
Details
Last Modified:
Feb 10,2017
Status:
Terminated
Severity:
2 Severe
Product:
(100)
Cisco 3900 Series Integrated Services Routers
Cisco AS5400XM Universal Gateway
Cisco VG204 Analog Voice Gateway
Cisco 1905 Serial Integrated Services Router
Cisco 2951 Integrated Services Router
Cisco 1812 Integrated Services Router
Cisco 888W Integrated Services Router
Cisco VG224 Analog Voice Gateway
Cisco 861W Integrated Services Router
Cisco 1803 Integrated Services Router
Cisco 881SRSTW Integrated Services Router
Cisco 878 Integrated Services Router
Cisco 892W Integrated Services Router
Cisco 886VA-CUBE Integrated Services Router
Cisco 7301 Router
Cisco 3845 NOVPN Integrated Services Router
Cisco AS5350XM Universal Gateway
Cisco 7206 Router
Cisco VG202 Analog Voice Gateway
Cisco 867 Integrated Services Router
Cisco 881SRST Integrated Services Router
Cisco 888E-CUBE Integrated Services Router
Cisco 881W Integrated Services Router
Cisco 861 Integrated Services Router
Cisco IAD888W Integrated Access Device
Cisco 887VA Integrated Services Router
Cisco 891 Integrated Services Router
Cisco 876 Integrated Services Router
Cisco 891W Integrated Services Router
Cisco 2821 Integrated Services Router
Cisco 888 Integrated Services Router
Cisco 7204 Router
Cisco 2911 Integrated Services Router
Cisco 1941 Integrated Services Router
Cisco IAD2430 Integrated Access Device
Cisco 7206VXR Router
Cisco 887VAM-W Integrated Services Router
Cisco IAD2801 Integrated Access Device
Cisco 887 Integrated Services Router
Cisco C881W Integrated Services Router
Cisco 1941W Integrated Services Router
Cisco 1801 Integrated Services Router
Cisco 887VA M Integrated Services Router
Cisco VGD 1T3 Voice Gateway
Cisco 1861 Integrated Services Router
Cisco 886 Integrated Services Router
Cisco 1921 Integrated Services Router
Cisco 3925E Integrated Services Router
Cisco 1811 Integrated Services Router
Cisco 2010 Connected Grid Router
Cisco 887VA-CUBE Integrated Services Router
Cisco IAD888 Integrated Access Device
Cisco 887VA-W Integrated Services Router
Cisco 1841 Integrated Services Router
Cisco 1906C Integrated Services Router
Cisco 886VA Integrated Services Router
Cisco 1802 Integrated Services Router
Cisco IAD887 Integrated Access Device
Cisco 888SRST Integrated Services Router
Cisco 871 Integrated Services Router
Cisco 7202 Router
Cisco 3945E Integrated Services Router
Cisco 2801 Integrated Services Router
Cisco 886W Integrated Services Router
Cisco 3825 Integrated Services Router
Cisco IAD2435 Integrated Access Device
Cisco 886VA-W Integrated Services Router
Cisco 1805 Integrated Services Router
Cisco 877 Integrated Services Router
Cisco 3825 NOVPN Integrated Services Router
Cisco 3845 RAN-O Integrated Services Router
Cisco 881 Integrated Services Router
Cisco 1861E Integrated Services Router
Cisco 2851 Integrated Services Router
Cisco 2811 Integrated Services Router
Cisco 888SRSTW Integrated Services Router
Cisco 887V Integrated Services Router
Cisco IAD2431 Series Integrated Access Device
Cisco IAD881 Integrated Access Device
Cisco 2921 Integrated Services Router
Cisco 2901 Integrated Services Router
Cisco 3845 Integrated Services Router
Cisco 3925 Integrated Services Router
Cisco 888-CUBE Integrated Services Router
Cisco IAD886 Integrated Access Device
Cisco 892F-CUBE Integrated Services Router
Cisco 7200 Series NPE-G2 Network Processing Engine
Cisco IAD887W Integrated Access Device
Cisco 7204VXR Router
Cisco 892 Integrated Services Router
Cisco 3825 IP RAN Integrated Services Router
Cisco VG224 Voice Gateway
Cisco 888E Integrated Services Router
Cisco 7201 Router
Cisco 3945 Integrated Services Router
Cisco IAD881W Integrated Access Device
Cisco 881-CUBE Integrated Services Router
Cisco 887W Integrated Services Router
Cisco 819 Integrated Services Router
Cisco IAD886W Integrated Access Device
Support Cases:
Known Affected Releases:
(1)
15.1(4)M
the issues is likely to appear on Cisco 3900 ISR router running 15.1.(4)M version.
the bug description does not provide any info about the impacts but the bug is classified with severity 2.
I think you should verify what router model you have using:
show version
show version | inc image
feel free to post these outputs in this thread if you need further help or you have other doubts.
Hope to help
Giuseppe
