Inter vrf - MPLS link
WimVS
Hello
I'm trying to setup a poc where I want to interconnect vrf's.
2 Branches with different subnets connected with a mpls connection.
I have following setup:
PC1 ---- SW1 -----SW2----PC2
Config SW1:
ip vrf MGMNT
rd 65000:200
route-target export 65000:200
route-target import 65000:200
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/1
 switchport access vlan 200
 switchport mode access
interface GigabitEthernet0/0
 no switchport
 ip address 10.10.10.1 255.255.255.252
 mpls ip
interface Vlan200
 ip vrf forwarding MGMNT
 ip address 10.100.10.1 255.255.255.0
router bgp 65000
 bgp log-neighbor-changes
 neighbor 2.2.2.2 remote-as 65000
 neighbor 2.2.2.2 update-source Loopback0
 address-family vpnv4
  neighbor 2.2.2.2 activate
  neighbor 2.2.2.2 send-community both
  neighbor 2.2.2.2 next-hop-self
 exit-address-family
 address-family ipv4 vrf MGMNT
  redistribute connected
 exit-address-family
ip route 2.2.2.2 255.255.255.255 10.10.10.2
Config SW2:
ip vrf MGMNT
 rd 65000:200
interface Loopback0
 ip address 2.2.2.2 255.255.255.255
 no switchport
 ip address 10.10.10.2 255.255.255.252
 mpls ip
interface Vlan200
 ip address 10.200.10.1 255.255.255.0
router bgp 65000
 neighbor 1.1.1.1 remote-as 65000
 neighbor 1.1.1.1 update-source Loopback0
  neighbor 1.1.1.1 activate
  neighbor 1.1.1.1 send-community both
  neighbor 1.1.1.1 next-hop-self
 exit-address-family
 exit-address-family
ip route 1.1.1.1 255.255.255.255 10.10.10.1
PC1:
ip: 10.100.10.10/24
PC2:
ip: 10.200.10.10/24
Both PC's can ping their gateway. If I want to ping from one side to the other however, pings don't return.
I'm not sure what's wrong here or is the virtual setup the cause here.
Any help appreciated.
Thanks a lot.
WimVS
Some show commands:
Is it normal behavior that there is no label for that one subnet, while SW2 (mirror config) does get a label for it's subnet.
SW1#show mpls forwarding-table
Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
Label      Label      or Tunnel Id     Switched      interface
17         Pop Label  2.2.2.2/32       0             Gi0/0      10.10.10.2
18         No Label   10.100.10.0/24[V]   \
                                       0             aggregate/MGMNT
SW2#show mpls forwarding-table
16         Pop Label  1.1.1.1/32       0             Gi0/0      10.10.10.1
18         Pop Label  10.200.10.0/24[V]   \
                                       13514         aggregate/MGMNT
SW1#show ip route vrf MGMNT
Routing Table: MGMNT
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.100.10.0/24 is directly connected, Vlan100
L        10.100.10.1/32 is directly connected, Vlan100
B        10.200.10.0/24 [200/0] via 2.2.2.2, 00:30:53
SW2#show ip route vrf MGMNT
B        10.100.10.0/24 [200/0] via 1.1.1.1, 00:30:46
C        10.200.10.0/24 is directly connected, Vlan200
L        10.200.10.1/32 is directly connected, Vlan200
Kind regards.
    Control-plane works, as you see the routes; data-plane is the problem, due to the missing label on SW1; try rebooting it.
Cristian Matei.
Hello Cristian,
thanks for having provided this useful suggestion!
At first sight SW1 looked like correct but compared to SW2 output the no label is like a ringing bell when troubleshooting MPLS issues.
control plane even when an IP only path exists.
the forwarding plane requires an MPLS end to end path working
L3 VPN use two labels the inner label is provided by MP BGP as an attribute of the MP NLRI.
SW1 failed to allocate a label to the locally attached route /FEC in VRF with real devices I would look to licensing problems in IOS XR or nexus NX OS but here the SW1 and SW2 are likely running IOS XE.
Best Regards
Giuseppe
