IPV6 Summary address
jaighobahi
Level 3
Level 3
Please, look at the three IPV6 addresses below.
2001:0DB8:0:0:7::/64
2001:0DB8:0:0:8::/64
2001:0DB8:0:0:9::/64
The book I am reading says the summary of the three addresses is 2001:0DB8::/48.
I thought the summary would be 2001:0DB8::/64.  If I am wrong, could you please explain how to summarize the three addresses.
Thanks.
ashirkar
Level 5
Level 5
Hello Jonathan,
You can refer this document
https://supportforums.cisco.com/docs/DOC-29256
I have shown how to calculate IPv6 prefix summarization.
Hope it helps you
Ashish Shirkar
Thanks Ashish.  So, I take it that both 2001:0DB8::/48 and 2001:0DB8::/64 are correct summary routes, depending on the range of addresses the summary route is expected to cover.  Correct?
