IpV6
Ibrahim Jamil
Level 6
Level 6
Hi Experts
the below are used IPV4 in private network , what is the equivalent in IPV6 how to configure it as IPV6
10.0.0.0/8
10.0.0.0/16
10.0.0.0/24
172.16.0.0/16
192.168.0.0/24
thanks
Jamil
5 Replies 5
vmiller
Level 7
Level 7
from wikipedia.
The address block fc00::/7 has been reserved by IANA as described in RFC 4193. These addresses are called Unique Local Addresses (ULA). They are defined as being unicast in character and contain a 40-bit random number in the routing prefix  to prevent collisions when two private networks are interconnected.  Despite being inherently local in usage, the IPv6 address scope of unique local addresses is global.
A former standard proposed the use of so-called "site-local" addresses in the fec0::/10 range, but due to major concerns about scalability and the poor definition of what constitutes a site, its use has been deprecated since September 2004 by RFC 3879.
more info here. http://www.ripe.net/ipv6-address-types/
Ibrahim Jamil
Level 6
Level 6
can u give sample IPV6 config for the below
10.0.0.0/8
10.0.0.0/16
10.0.0.0/24
172.16.0.0/16
192.168.0.0/24
thanks
thanks
Hi vmiller
i have added the private IP of 192.168.0.0/16 and i convertit to IPV6.i have got the below , pls explain the value highleted in red
Hostfrom :fe80::c0a8:1-------------------------TO:fe80::c0a8:fe   ------What is the fe
netmask:120    why 120?
thanks
