IR829 WAN failover to Cellular and viceversa
bas123
Can someone help me how to configure a IR829 for WAN failover to cellular 0 and vice-versa depending on network presence or failure
Bas
9 Replies 9
the below should do it (important parts marked in bold):
version 15.5
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 20
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829GW-LTE-GA-ZK9 sn FGL19472082
redundancy
controller Cellular 0
lte sim max-retry 0
lte failovertimer 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface GigabitEthernet0
no ip address
shutdown
track 1 ip sla 1 reachability
interface GigabitEthernet1
switchport
switchport mode access
switchport access vlan 10
desc To Switch Fa0/1
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
description Link to Primary ISP
ip address dhcp
duplex auto
speed auto
interface Cellular0
description Link to Backup ISP
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip nat inside
no ip http server
no ip http secure-server
ip nat inside source route-map ISP_1 interface GigabitEthernet5 overload
ip nat inside source route-map BACKUP_ISP interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet5 dhcp track 1
ip route 0.0.0.0 0.0.0.0 Cellular0 20
route-map ISP_1 permit 10
match ip address 1
match interface GigabitEthernet5
route-map BACKUP_ISP permit 10
match ip address 1
match interface Cellular0
event manager applet CLEAR_NAT
event track 1 state any
action 1.0 cli command “enable”
action 2.0 cli command “clear ip nat translation *”
action 3.0 cli command "end"
dialer-list 1 protocol ip list 1
access-list 1 permit 192.168.10.0 0.0.0.255
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet5
frequency 3
ip sla 1 start-time now life forever
control-plane
line con 0
stopbits 1
line 1
stopbits 1
line 2
script dialer lte
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
rxspeed 100000000
txspeed 50000000
line 4
no activation-character
no exec
transport preferred none
transport input all
line 8
no exec
rxspeed 100000000
txspeed 50000000
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
login
transport input none
no scheduler max-task-time
end
Hi @Georg Pauwen ,
Thank you for your reply.
I have followed almost same config as yours except WAN port. I am using Gi0 instead of Gi5, as I am connecting through SFP.
Issue: I couldn't get internet (ping 8.8.8.8) even when connected to WAN only without cellular0, what could be the issue here at WAN side?
hoping for your help again.
sh running-config below:
lte sim data-profile 1 attach-profile 1 slot 0
vlan 10
name data10
description Primary Link
ip address dhcp
ip nat outside
description Connection to LAN side
no ip address
no ip address
no ip address
no ip address
interface Wlan-GigabitEthernet0
no ip address
interface Wpan2
no ip address
ieee154 txpower 25
no ieee154 fec-off
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
description Secondary Link
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface wlan-ap0
ip unnumbered Vlan1
interface Vlan1
description $ETH_LAN$
ip address 10.10.10.1 255.255.255.128
ip tcp adjust-mss 1452
interface Vlan10
ip nat inside
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source route-map Primary_Link interface GigabitEthernet0 overload
ip nat inside source route-map Secondary_Link interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 track 1
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0
frequency 30
ip sla schedule 1 life forever start-time now
ipv6 ioam timestamp
route-map Secondary_Link permit 10
match ip address 1
route-map Primary_Link permit 10
match ip address 1
match interface GigabitEthernet0
access-list 23 permit 10.10.10.0 0.0.0.127
control-plane
Hello Bas,
the configuration looks good actually. What is the LED status of interface GigabitEthernet0 ? Do you get an IP address on that interface at all ?
Yes I get IP address at Gi0 and even LED is Green.
When I take WAN cable out of Gi0, it still keeping IP and status as UP. It's behaving weird.
How could I know what medium its using while I ping/access internet?
sh track - always showing Reachability is Down.
Hi @Georg Pauwen,
I see the problem is in this line
With this, "sh track" always shows DOWN as it don't help data pass pass through Gi0.
And this statement is in correct,
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 dhcp track 1
Hope for your support
Bas
Hello Bas,
by default, the ping is sourced from the outgoing interface, GigabitEthernet0 in your case. Either way, if you get a public IP address on GigabitEthernet0, the IP SLA, in theory, should work, and reachability should be up.
When you do a 'show ip route' what default route is displayed in your routing table ?
Hello Bas,
try and add the static route below:
ip route 8.8.8.8 255.255.255.255 GigabitEthernet0 dhcp
Hello
nterface Vlan1
no ip address
You sure your have suppose to static addressing here, if so make youve apllied the correct ip/subnet mask
Also check your interface status.
show ip interface brief
Regards you cellular connection,make sure the sim is actually in the correct slot, default is 0 ?
show cellular 0 profile
show interface cellular
show cellular alll
Lasty I dont see you allowing ip regards the defined dialer group
dialer-list 1 protocol ip permit
Kind Regards
Paul
Hello
Can you elaborate on the actual topology-
Are  you using single or multiple wan rtrs, Network translation any routing protocols ?
Kind Regards
Paul
