Is Cisco 867VAE supported in CNA (Cisco Network Assistant)?
Alejandro Brown
i want to know if the routers model Cisco867VAE are supported in Cisco Network Assistant (CNA).
The documentation is confused because for example in the case of switches Catalyst 2960X, in the datasheet not appears and in the realease note appears.
Other weird thing is that the only models of Cisco 800 series supported in CNA are all end of sale models. Does this mean that the new 800 series models will not be supported?
Alejandro Brown
Robert Brim
Routers
Cisco 800 Series Small Office Home Office Routers: C-831, C-836, C-837, C-851, C-857, C-876, C-877, C-878, 877M
A list of supported devices:
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/network-assistant/datasheet-c78-730210.html
