IS-IS into routing table
rossmillan
Im new to IS-IS, and Im trying to work out how IS-IS routes get into the routing table? I read that IS-IS is working at layer 2. I am following the cisco press BSCI exam certifcation guide, but I must be missing a command or something because my configuration does not end up in the routing table.
For example:
interface Serial1/0
no ip address
encapsulation frame-relay
serial restart-delay 0
no dce-terminal-timing-enable
interface Serial1/0.1 point-to-point
ip address 140.100.32.2 255.255.255.0
clns enable
frame-relay interface-dlci 931
interface Serial1/0.3 point-to-point
ip address 140.100.16.2 255.255.255.0
clns enable
frame-relay interface-dlci 631
router isis
net 49.0002.0000.0000.000b.00
R2#show clns inter
Serial1/0 is up, line protocol is up
CLNS protocol processing disabled
Serial1/0.1 is up, line protocol is up
Checksums enabled, MTU 1500, Encapsulation FRAME-RELAY
ERPDUs enabled, min. interval 10 msec.
RDPDUs enabled, min. interval 100 msec., Addr Mask enabled
Congestion Experienced bit set at 4 packets
CLNS fast switching enabled
CLNS SSE switching disabled
DEC compatibility mode OFF for this interface
Next ESH/ISH in 2 seconds
Any help appreciated
Ross.
royalblues
Level 10
Level 10
Ross,
You are missing the "Ip router ISIS" command under the interfaces.
HTH, rate if it does
Narayan
