Is is possible to configure SIP NAT on Cisco ISR G2 router?
Dmitriy_Ermakov
Hello!
I want to setup network:
Asterisk (Digium) or ahother SIP client => Cisco ISR G2 => SIP Provider.
Asterisk's private IP is 10.0.0.10/24, SIP port 5060/UDP
Cisco ISR's G2 private IP is 10.0.0.1/24
SIP Provider's public IP is 10.8.0.1/24, SIP port 5120/UDP
Cisco ISR's G2 public IP is 10.8.0.10/24
I want to configure NAT on the Cisco ISR G2 and Zone-Based Firewall:
I want to configure something like this:
class-map type inspect match-all ICMP-LAN-to-WAN
 match protocol icmp
class-map type inspect match-all SIP-LAN-to-WAN
 match protocol sip
policy-map type inspect SIP-LAN-to-WAN
 class type inspect SIP-LAN-to-WAN
  inspect
 class type inspect ICMP-LAN-to-WAN
  inspect
 class class-default
  drop
zone security LAN
zone security WAN
zone-pair security LAN-2-WAN source LAN destination WAN
 service-policy type inspect SIP-LAN-to-WAN
interface FastEthernet0/0
 description LAN
 ip address 10.0.0.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 zone-member security LAN
interface FastEthernet0/1
 description WAN
 ip address 10.8.0.10 255.255.255.0
 ip nat outside
ip nat service sip udp port 5120
ip nat inside source static udp 192.168.0.1 5060 1.1.1.1 5120
Could you help me with configuration?
Will this example configuration work or I should change something?
My Asterisk will work as SIP client and it will send first SIP-REGISTER packet.
Leo Laohoo
Talk to your provider FIRST.
In most cases Asterisk won't work with ALG enabled.
