Is it possible with just an 828 and a 6015?
levi.bushman
I'm trying to set up a tiny network between 4 buildings using 828s at each building with a 6015 joining them. I have no need to go anywhere other than between the 828s (no uplink to the rest of our network, or the internet for that matter). All I can get my hands on at this point are the four 828s and the 6015, so I have no ATM uplink... Is this something I can overcome? Suggestions would be GREATLY appreciated! Thanks!
thomas.chen
Level 6
Level 6
ATM uplink is used as Interface between Local LANs and ATM network.If there is no need for Internet access or remote access ATM uplink is not needed.
Wilson Samuel
Level 7
Level 7
Hi Levi,
Could you please elaborate the matter a bit more. I guess its 828 G.HDSL which is connected to a Service Provider or something which gives an HDSL link to the 6500 Switch.
Moreover what module you are trying to connect to on 6500?
Wilson Samuel
