Is NAT support H.323?
wmmak
Hi all,
I come across a case that I have two Video conferencing end-device interconnecting with routers and Internet.
One end router needs to configure NAT for VC and the other end of VC binds real IP address.
I find that private-IP VC can send video but not voice to other end public-IP VC. And the public-IP VC cannot send any to private-IP VC.
Would the IOS has some limitation support NAT for H.323 or other reasons?
Thanks in advance.
Best Regards,
mak
amit-singh
Level 8
Level 8
Hi MAK,
Yes NAT support all H.323 signaling type.
Please see the link below for more info:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t5/dth323v2.htm
HTH, Please rate if it does.
-amit singh
