is that possible to do password recovery without removeing the stack cable
miada.murad
hi
i have two stacked switch ( stacked ) 3750
i need to do password recovery
1- i switch off both switch
2- plug the console on slave switch
3- press mode button on slave switch ,,, the master switch boot normally
4- do the steps for password recovery including ( renaming the config.text )
but when i boot the switch
it did not bypass the the configuration ( it ask for password again )
my question is
is that possible to do password recovery without removing the stackcable ?
waiting for reply
regards
Leo Laohoo
You need to remove the stacking cable or else the switch you're doing the password recovery will immediately join the stack master and copy the config.
