ISDN and Dialer Profile
zulqurnain
Level 3
Level 3
has anyone configured an ISDN using Dialer Profile to backup and MPLS Line meaning it will not be a serial interface or frame relay technology but it would be an ethernet.
any guide or help in this would be helpfull.
leighharrison
Level 7
Level 7
Hi there,
Try configuring the dialer interface and put in the command "backup interface xyz" and that should sort it.
I've done thing having an ethernet interface as a backup to a tunnel interface and it works a treat.
Hope that helps,
LH
Please rate all posts
have a look at the following configuration example:
interface FastEthernet0/0
backup interface Dialer1
ip address 192.168.1.1 255.0.0.0
mpls ip
interface Dialer1
ip address 172.16.1.3 255.0.0.0
encapsulation ppp
dialer pool 1
dialer remote-name Remote_1
dialer string 1234
dialer persistent
dialer-group 1
mpls ip
ppp authentication chap
This sample configuration is from the following document/guide:
ISDN Backup in MPLS Core
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_2/gtisdnbk.htm
GNT
thanks everyone,
i will illustrate my problem more clearly,
my router is connected to a modem and that modem is connected to a MPLS cloud (ISP) and same situation is on both ends.
so suppose mpls not working, no communication, there is no way i can tell the router to know that the mpls is not working since the router is connected to the modem and since it's ethernet it will never know? so i hope it's clear what i am trying to get... thanks in advance
