ISDN backup problems
kokencisco
I configured a ISDN backup line with dialer-watch between a CISCO 7200 and Cisco 1721 but the connection is UP only for 20 seconds then it is DOWN.
Can you help me?
5 Replies 5
check if you have a dialer idle-timeout set to 20 seconds, or a dialer fast-idle, if so, you might want to increase those values (keep in mind that
Dialer Watch checks for the primary route at the interval configured with the dialer idle-timeout).
Otherwise, can you post your configurations (both sides) ?
GP
On the 1721 the configuration is:
interface Dialer1
ip address xxx.xxx.xxx.xxx 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer remote-name 7200-1
dialer idle-timeout 3
dialer string 00000000
dialer watch-disable 10
dialer watch-group 1
no cdp enable
ppp authentication chap callin
On the 7200 the configuration is:
interface Dialer1
description Backup from 1721
dialer pool 1
dialer remote-name 1721
dialer idle-timeout 86400
If you have to know more, ask me.
thank you
Hi, we've run into a very similar problem (several times) that turned out to be the Service provider provisioning, somewhere within their ISDN, a "voice" service instead of "data."
I suggest running a "debug isdn q921 and debug isdn q931" capture this info (the reason for the disconnect is always in the output - look it up and send it to your Service provider).
Good luck,
Steve
stupid question maybe, but I assume you have your dialer-group and dialer-list configured ?
GP
No problem,
Yes dialer group and dialer list are configurated!
